13th Oct 2021, 2:22 pm | #1 |
UNITRA DG-203 help
Hello out there. Can anyone help me with this Polish unit. I’m trying to work out how the phono is amplified at the main chassis. I don’t have the deck here but I’ve hooked mine up to the phono in and the signal is very poor. Does this unit have a phono stage amplifier with the deck? Anyone got a schematic?
13th Oct 2021, 4:58 pm | #2 |
Re: UNITRA DG-203 help
This is unlikely to be for a magnetic cartridge only a medium output crystal type.
13th Oct 2021, 6:08 pm | #3 |
https://www.oldradio.pl/karta.php?numer=363
The same as Unitra Diora Meteor 2? Circuit diagram: https://elektrotanya.com/meteor-2_am...wnload.html#dl |
13th Oct 2021, 7:45 pm | #4 |
Well the ECL86 will only work with a ceramic/crystal cartridge, so I suspect the OP is trying to play a MM into it. Result = very low output.
Edward. |
13th Oct 2021, 8:10 pm | #5 |
That schematic looks really helpful. Thanks. I’ll let you know how I get on
15th Oct 2021, 8:56 pm | #6 |
I think that’s spot on. I’m a bit confused because I expecting be able to adjust the output of my signal generator to about 3mV and get amplified signal. But it does need much more than that. Have I miscalculated the o/p if a Crystal cartridge? Thanks by the way
15th Oct 2021, 9:01 pm | #7 |
Just looked at specs for Crystal cartridges. Now I get it! 200mV not unusual
