29th Aug 2010, 8:57 pm | #1 |
Converted 746 won't ring
I was recently given a GPO 746 and decided to convert it according to the instructions on britishtelephones.com. It's my first attempt at anything like this but everything went pretty smoothly. I'm getting a good clear reception and can make and receive calls no problem. However I'm getting no ring at all on incoming calls.
I've trawled through loads of helpful advice on this forum but nothing which has fixed my issue. So far I have tried...
None of these have resulted in a ring, or helped me narrow down the problem. There doesn't seem to be any movement from the bell arm during ringing at all, although I can move it freely by hand so it doesn't appear to be stuck. Is there anything else I can try to help narrow down the issue? |
29th Aug 2010, 9:05 pm | #2 | |
Re: Converted 746 won't ring
Hello and welcome to the forums.
29th Aug 2010, 9:11 pm | #3 |
I take this to be 1.2K across the two coils in series, and the individual coils to be 520 ohm and 500 ohm respectively, is that a correct assumption? If so, that is near enough the correct values, and the 3.3K resistor in series would be correct.
29th Aug 2010, 9:19 pm | #4 |
Yup, that's right. Apologies, I should have been clearer.
30th Aug 2010, 9:17 pm | #5 |
Have you a multimeter that will measure a.c. volts and give a meaningful reading from a 400 millisecond burst of ringing current? If so, connect it across the bell-motor connections, clip the cradle-switch down, and ring yourself up. You should see if you have ringing voltage at the bell coils.
If no reading, work backwards by metering terminals T4 and the joined-up terminals T16, 17, 18, 19. You should have ringing voltage here, which will be anything from 75V a.c. downwards. If still no reading, leave one meter lead connected to joined-up terminals T16, 17, 18, 19 and disconnect the blue wire of your standard BT plug and lead that goes to terminal T5 (or T6) and connect your other meter terminal here, still set to a.c. volts. By doing this you will be able to tell if you are getting ringing voltage to your telephone. If not, your lead or plug is likely to be faulty (it's not unknown for the plug-end connectors to be open-cct!). If you only have an ohm-meter or continuity tester, check out your plug and lead for continuity. Looking at your plug with the contacts uppermost and away from you, the lead towards you with the detent-clip on your right you should have pins 2, 3, 4, 5 (1 and 6 aren't used) connected to white, green, blue, red respectively. Pin 2 should be connected to joined-up terminals 16, 17, 18, 19. Pin 3 isn't used. Pin 4 should be connected to terminal 6, joined to 5, with your resistor between 5 and 4. Pin 5 should be connected to your terminal 8. Note the plug numbers are opposite to the socket numbers (2 in the plug to 5 in the socket, 3 in the plug to 4 in the socket, etc...). Do the above and report back.
Regds, Russell W. B. G4YLI. |
30th Aug 2010, 10:40 pm | #6 | |
Many thanks for helping me sort this out |
31st Aug 2010, 2:47 pm | #7 |
That's funny I did exactly the same thing, I ended up belling out the lead to work out what needed to go where. Is that diagram incorrect or are there just several standard non-standard leads?
31st Aug 2010, 3:34 pm | #8 | |
I have also come across rogue IDC connections at the plug-end, where the little connector hasn't been pushed home properly! Buzzing out the wires will turn up this fault as well, if present. A quick check can be made, if meterless but in posession of a torch, by shining a light underneath the plug to reveal the wiring colours. Works better on some than others.
31st Aug 2010, 7:41 pm | #9 |
I have three identical looking leads which I've just tested, and one is wired as in the diagram (black to pin 2), and the other two are reversed. I guess the moral is always to check which pin goes to which wire.
