Old 29th Jun 2018, 4:08 am   #1
em536716
em536716's Avatar
Default Thorn Ultra 1500 restoration
The restoration project of the Ultra, with the wonderful Thorn 1500 chassis.
After fixing the simple frame fault, (a quick swap of the frame output valve) I went through and changed capacitors in the line stage
Both stages wouldn’t lock hold so that needed to be looked at.
At this point I cleaned the chassis... to then discover after doing which, I lost video.
I went paranoid and took out every transistor to check for shorts... ended up breaking one of the pins on one... replaced that and reinstalled all of them... still no picture. I then checked the HT feed... (4 HT rails and video transistors runs off HT 3).
Off the smoothing caps I got around 260 volts which seemed to be right, from there it goes through a limiting resistor, which drops the voltage down to 160... OPEN CIRCUIT!
I’ve never worked on a transistor/valve set before so it was a learning experience. I really do like the 1500 chassis, after I examined the diagram and fixed it... it’s quite fun.
I changed the 82K resistor straight away, and had a lovely 160 volt HT (I had to temporarily put 4 resistors in parallel and series to make a higher wattage resistor until the next batch arrives) and plugged my pattern generator in once again... and was greeted with a messy looking image... after some adjustments, (still need to go through the frame stage as there’s slight bending, and adjusting magnets isn’t fixing it!
I also changed a few resistors in the line stage which drifted, but from what I can tell, most of the resistors on the set are fairly good quality so I left them in place.
I also changed every electrolytic capacitor out for modern ones as the ones in place looked very old and dodgy... I took one out which had completely leaked
I know the ultra is quite rare so I’m definitely going to preserve it!
A simple problem caused me to do everything backwards... you live and learn
To add, I also cleaned up the cabinet, and surprisingly, it looks as good as new!
ID:	165328   Click image for larger version
ID:	165329   Click image for larger version
ID:	165330   Click image for larger version
em536716 is offline
Old 29th Jun 2018, 9:38 am   #2
Hybrid tellies
Hybrid tellies's Avatar
Default Re: Thorn ultra 1500 restoration
Looks very good, what tube is it? I have seen many different model 1500's in my time but have never seen this white Ultra model before.
Simon
BVWS member
Hybrid tellies is offline
Old 29th Jun 2018, 3:46 pm   #3
em536716
em536716's Avatar
I surprisingly cannot find any documentation of it online.
It looks to be a Gold Star Mazda Tube. Looks to be about 20 inches?
em536716 is offline
Old 29th Jun 2018, 7:21 pm   #4
Restoration73
Restoration73's Avatar
White was a popular Ultra colour, as used on the 6816 (1590) portable. Your set
may be model 6800, 6807, or 6813. Tube is CME2013R.
Worth upgrading R44, 47k, to 1W rating (30FL2 screen grid)
There is slight underscan, check geometry with a circle pattern or test card.
Restoration73 is offline
Old 30th Jun 2018, 5:42 am   #5
em536716
em536716's Avatar
Yes you are right. An 6807 I believe. Will change when I next take it down to the workshop if I haven’t already (I didn’t change a few but can’t recall). The magnets on scan coils have become very weak causing the image to twist and distort. I’ve managed to remagnitise them all a little, however I may need to add additional magnets to fit the top and bottom!
em536716 is offline
Old 30th Jun 2018, 7:20 am   #6
Focus Diode
Focus Diode's Avatar
Indeed, but this shouldn't be done without keeping an eye on the boost voltage. Set too high can cause the EHT tray to fail.
If the correct voltage still results in lack of width check the scan correction capacitor, the width control and its series resistor.
Brian
Focus Diode is offline
Old 1st Jul 2018, 1:34 am   #7
mickash
Make sure the scan coils are pushed forwards, towards the bowl of the tube and twisted correctly to level the scan.
Michael.
mickash is offline
Old 3rd Jul 2018, 6:30 am   #8
em536716
em536716's Avatar
Default Re: Thorn Ultra 1500 restoration
Just a few updates on the Ultra.
Has been running perfectly over the past few days. Replaced 82k resistor with appropriate replacement.
I also had to replace the scan coils, as I later found out the original scan coils must’ve had a shorted turn, as the width control would barely fill the screen! There was quite a bit of bowing on the top and sides which I couldn’t adjust out with magnets. Have used the scan coils from a scrap Murphy TV I have, and now all is well!
I’ve attached a picture of the BBC test card you can get off a freeview box (however I wouldn’t use this since it’s meant for widescreen and not accurate)
I think now all I have to do is treat the cracks and chips, and possibly make up some legs for it, and it’ll be done 🙂
ID:	165478   Click image for larger version
ID:	165479   Click image for larger version
em536716 is offline
Old 3rd Jul 2018, 6:34 am   #9
em536716
em536716's Avatar
All seems fine now after the scan coils swap. Can’t believe I missed that, all voltages seem healthy and the set runs fairly cool. The heat mainly came off those scan coils!!
em536716 is offline
Old 3rd Jul 2018, 12:19 pm   #10
Focus Diode
I see the linearity sleeve is missing between the CRT neck and scan coils, yet the vertical linearity is close to perfect!
There's a chance the old coils could have overheated if the linearity sleeve was inserted too far in.
Anyway, well done. I once had lack of width on a 1500 caused by the scan coils.
Brian
Old 4th Jul 2018, 5:36 pm   #11
em536716
em536716's Avatar
I removed it at first just to test fit it, but decided on not fitting it back. The picture looks as best as it’ll ever be so I’ll nust leave it now.
Does anyone have any legs for this?
em536716 is offline
Old 5th Jul 2018, 9:45 pm   #12
jayceebee
jayceebee's Avatar
Well done for saving another 1500 but I feel you still have issues around the video stages VT8/9. The chassis is an economical and reliable design but it is capable, depending on the CRT of pretty fair results. Have a look at my unfinished Marconi 4821 with it's slightly soft Mullard CRT.
John
jayceebee is online now
