Old 18th Sep 2021, 12:06 am   #1
M3VUV51
Default AVO Mk8 case repair.
Got this mk8 arrive, was in a state well, after struggling trying to get the bakelite case out of the steel case ,i resorted to smashing it out!, wasnt realy bothered as i had another spare, the spare had a damaged corner, so made a mould for the busted corner out of bits of the case i smashed up, i smeared the inside corner of the steel case with grease, as a release agent, then pilled a big wad of p40 after inserting the damaged bakalite case into the steel outer, then befor the fiberglass mix set i clamped the old piece of bakelite corner piece on the inside of the two cases with a pair of mole grips and let it set, after some carefull trimming with a rotary burr if fits together like a glove, i mixed coffee powder in the resin, it almost matches color wise, not to bothered as i will spray it and its not visible once the metal outer is fitted, talking of which what color should the steel outer be ,hard to tell as it was repainted badly and the inner surface of the steel was a sort of gold hammer finish, it's just in self etch primer at the moment, will buy some spray paint and clearcoat when i know what color to get, see pics . so folks should the outer steel case be black or brown, or a gold hammer finish like the paint was on the inside?
thanks in advance.
ID:	241545   Click image for larger version
ID:	241546   Click image for larger version
ID:	241547   Click image for larger version
M3VUV51 is offline
Old 18th Sep 2021, 1:12 pm   #2
Superscope
Default Re: AVO Mk8 case repair.
The Steel Shell on the Avometers could be a number of different Colours.
A Hammered Silver Finish was common, but more so on the Model 7's.
A Matt Grey/Blue is commonly found on Early Military Avo 8's.
Yours is clearly Military, but probably not old enough.
However, the most common colour for the Pan-Climatic Avo 8, which
is the version you have there, seems to be the Hammered Gold Colour.
The fact that you have found this colour oversprayed on the inside of the Shell,
pretty much confirms your Meter would have had the Hammered Gold finish.
Ian
Superscope is offline
Old 18th Sep 2021, 1:31 pm   #3
Am I thick or is there no visible damage to the Avo in the photos?
Old 18th Sep 2021, 3:55 pm   #4
Superscope
Your definately not Thick !
The Photos were probably not the best choice for the Subject Matter in question.
The OP was referring to the Back Case that has been removed before those
Photos were taken.
So yes, you are correct, there is no apparent damage to the Meter workings
themselves! (Hopefully).
Ian
Old 18th Sep 2021, 8:06 pm   #5
That is a relief, time for the metal bashing hammers.
Old 18th Sep 2021, 9:21 pm   #6
M3VUV51
the main body of the meter is fine but i had to destroy the bakelite on the inner to get the steel outer case bare,its a spare bakelite outer case i repaired ready to fit in the steel outer once its painted.
M3VUV51 is offline
Old 18th Sep 2021, 10:21 pm   #7
M3VUV51
some pics of the case etc,the repair looks wose than it is due to the camera flash but isnt visible when its in the case.,will post some pics of another meter i have,it reads about %20 high on most ranges,its on the tuit pile lol.,the meter is in A1 cosmetic condition,its a mk 1 i assume.
Name:	case outer.jpg
ID:	241602   Click image for larger version
Name:	corner fixed ish.jpg
ID:	241603   Click image for larger version
Name:	top corner repair.jpg
ID:	241604   Click image for larger version
Name:	faulty meter.jpg
M3VUV51 is offline
Old 19th Sep 2021, 1:25 am   #8
M3VUV51
Originally Posted by M3VUV51 View Post
heres a pic of the crud that came off the steel case when stripping it using electrolysis
oh well lets have another try!
M3VUV51 is offline
Old 19th Sep 2021, 9:14 am   #9
Station X
Station X's Avatar
When uploading pictures click the preview button before clicking submit.
Graham. Forum Moderator
Station X is online now
Old 19th Sep 2021, 11:36 am   #10
Herald1360
Herald1360's Avatar
Wondered what an AVO Mk8 was since the AVO 8 only got up to Mk7. The pictures explained- it's an earlyish AVO 8 Mk?
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 19th Sep 2021, 12:18 pm   #11
M3VUV51
and another try.
M3VUV51 is offline
Old 19th Sep 2021, 3:43 pm   #12
Sinewave
Sinewave's Avatar
I wondered that too. It's a Mk2 or Mk3.
Avometer, vintage Fluke and Marconi collector. Also interested in vintage Yaesu and KW.
Sinewave is offline
Old 19th Sep 2021, 7:27 pm   #13
M3VUV51
well the ser no is:22152-c-354,also it doesent have the small raised divit between the range knobs where the mk normaly is,so i assume its an early mk1,this is my other meter we are talking about that reads high,not the panclimatic,maybe i should of made it clear,its the one in the second set of pics.
M3VUV51 is offline
Old 19th Sep 2021, 10:10 pm   #14
Sinewave
Sinewave's Avatar
Maybe it's had the movement swapped out for an earlier model, the front of that is a late Mk2 or Mk3. The Mk1 is different in appearance from the DC ranges and the test lead connectors would be the domed headed ones.
Sinewave is offline
Old 20th Sep 2021, 3:03 am   #15
M3VUV51
well the movement doesent have painted magnets and the front connectors accept lug type probes,as in there is no hole in them for a banana plug,see pic attached,its a mk1 as far as i can tell.
M3VUV51 is offline
Old 20th Sep 2021, 4:50 pm   #16
Sinewave
Sinewave's Avatar
The photos on post 1 are not of a MK1. You've now posted a completely different photo of a different meter.
Sinewave is offline
Old 20th Sep 2021, 7:47 pm   #17
M3VUV51
should of made it clear,sort of got the threads mixed up,the panclimatic is good except i still have to paint the case and fit it,the mk1 reads high,i have another tread running,so far its got me beat!.
M3VUV51 is offline
Old 25th Sep 2021, 10:55 am   #18
M3VUV51
heres some pics of the panclimatic tidied up,some pics as well of what i used to redo the lettering,i went to the local car shop to get some white cellulose touch up,got this thing as per pic,it has a brush also under the cover a almost like a hyperdermic needle,made redooing the lettering a doddle,it was brilliant white,after removing the excess paint with cotton buds and thinners,i gave it a final polish on the lettering with brasso(after masking off),the brasso yellowed the white paint,makes it look more original,the paint on the case ,is hammerite hammer finish,although it doesent display the hammer finish,the paint was ok when it was finiganns the company who now have the brand have ruined it,it doesent give a hammer finish and is like gnatts ****,i have emailed the company to complain but nothing heard from them yet.
ID:	242090   Click image for larger version
ID:	242091   Click image for larger version
ID:	242092   Click image for larger version
ID:	242093   Click image for larger version
M3VUV51 is offline
