12th Sep 2021, 1:48 pm | #1 |
Datron 1071 Lithium Backup Battery
Hello,
I have a Datron 1071 that works ok Need advice how change the battery without loosing the cal values it is soldered in not in a socket I am going to modify to use a 1/2 AA socket The present battery is dated 1994 and still reads 3.6v I know I need to piggy back another battery in parallel or have the unit powered but need to un earth the soldering iron regards john davis uk |
12th Sep 2021, 2:23 pm | #2 |
Re: Re datron 1071 Lithium Backup Battery
Yes, you're right. Just keep the instrument powered, avoid touching anything lively, and perhaps unplug your iron for a few seconds.
John |
12th Sep 2021, 2:29 pm | #3 |
And avoid dragging the solder wire against anything else, or the case.
David |
12th Sep 2021, 2:38 pm | #4 |
Have an ask around to see if the calibration parameters can be displayed or downloaded by GPIB, then you can have a safe copy if such a facility exists.
12th Sep 2021, 2:53 pm | #5 |
The procedure is attached
Craig |
21st Sep 2021, 5:25 pm | #6 |
hello,
thanks yes I missed the cal section in the manual john davis uk |
