Old 30th Nov 2011, 3:32 am   #1
Ebrew567
Default Advance P1 Sig gen - What HT Voltage?
A previous owner has replaced the power transformer and PSU with a new concoction. I can have an HT voltage from 135 to 185 Volts DC (as measured at the second electrolytic smoothing condenser), by changing transformer taps (another story). The unit has had extensive replacement of old caps, electros and composition resistors (I'm still completing that).
What HT voltage should I aim for? Thanks
Ebrew567 is offline
Old 30th Nov 2011, 8:12 pm   #2
WME_bill
Default Re: Advance P1 Sig gen - What HT Voltage?
Advance P1. I have never seen a manual. Produced about the same time as the E2, which followed the Q1 and B4 models. All very much the same in performance. Must have been some marketing idea, or special models for the Military. But the usual oscillator valve for these models was 6J6 or 12AT7. Run them between 150 and 200V I suggest, the 135v may be a bit low. If you cannot get enough RF at max output, or it fails on the highest frequency, change the valve and/or increase the voltage. I suggest it is not very critical. Bill m0wpn
WME_bill is offline
Old 2nd Dec 2011, 4:42 pm   #3
BobGreen
The Advance E1 was like this - https://www.vintage-radio.net/forum/...6&d=1301076100
BobGreen is offline
Old 9th Dec 2011, 3:30 am   #4
Ebrew567
Thanks to the people who came back.
I increased the volts a bit to 140Vdc, I'm sure it should be higher, but its working fine on all bands and will be put to work as is (until I get around to it again).
Appreciated if WME Bill would send me a PM (Re his info on Avo AFM2)
Ebrew567 is offline
Old 9th Dec 2011, 8:09 am   #5
Chaparal
Chaparal's Avatar
Here is the P1 signal gen manual.
It's in djvu format
Peter
File Type: zip Advance P1 - Signal Generator (djvu).zip (48.5 KB, 201 views)
Chaparal is offline
Old 27th Jun 2012, 10:01 pm   #6
amornummi
I have recently inherited a P-1 . Very clean , ex college.
Mains input 250 volts. Heater volts 7.2 . HT winding giving 57 volts. Measures 135 ohms.
Ht after silicon diode is 68 volts.
Audio out 20 volts peak. RF out at 3.5 megs is bit low at minus 10 Dbm.Works happily on all freq ranges to 100+ megs
Tempted to fit doubler to get a bit more output, an lose some lt to 6.3 v.
amornummi is offline
Old 13th Jan 2015, 9:01 pm   #7
Station X
Station X's Avatar
I'm restoring one of these generators. Having replaced the SenTerCel rectifier with a 1N4007 diode and reformed the smoothing caps, the HT is sitting at about 68V DC. This is the same as amornummi saw.
C1 which sits directly across the HT winding of the mains transformer is only rated at 150V, so I wouldn't expect the HT to be particularly high.
The real test will come when I measure the RF output voltage.
R2 in my SG is 3.3K and looks to be original, but the parts list says it should be 560R.
Graham. Forum Moderator
Station X is online now
Old 14th Jan 2015, 5:16 pm   #8
Station X
Station X's Avatar
Some test results with 68V DC HT.
Audio output 10.6V RMS at 384Hz into open circuit. Spec 8V at 400Hz.
RF output checked across 75R load. Spec 100mV RMS on all ranges.
Range A. Unable to measure on a 20MHz scope.
Range B. 127mV RMS at 20MHz.
Range C. 141mV RMS at 10MHz.
Range D. 148mV RMS at 3MHz.
Range E. 127mV RMS at 1MHz.
Range F. 162mV RMS at 300kHz.
Modulation depth on 2MHz RF signal 28%. Spec 30%.
So I conclude that 68V DC HT is adequate.
Old 21st Aug 2015, 11:14 am   #9
Ozzie41bob
Hi, just about completed restoration of one of these P1 units that someone with a blue and white striped apron has been at. I found R2 as per "Station X" was not what the manual describes, mine had what appeared to be an original 2K7 but also had a 5uF electro across it, I found this unusual for an oscillator so removed it and the oscillator stopped. Then R2 was returned to 560R and it fired up, so I have no idea why there appears to have been a factory mod to change this value. I also found the output attenuator had been blown up, all the resistors on the rear wafer were destroyed, the wafer was not all that well either. Note that the manual does not reflect the situation of two wafers or the shield between them. I am completing a revised circuit diagram for this part of the circuit.
Ozzie41bob is offline
