15th Aug 2015, 12:31 pm | #1 |
Feedback TWG Function Generator
Has anyone a schematic or manual for the above? The one I have has no OP.
I've reformed the two big reservoir caps and had a signal out of the 2v sine/square/triangle OP's (2v 1000 ohm ), however when I turned the voltage output pot fully clockwise, the trace got cut off at the bottom. I found a loose wire on the bridge rectifier, which was probably the cause. There was nothing from the red/black terminals on the right. However, I now have nothing except a floating DC trace on the scope. By floating I mean the trace floats up and down on the screen. I've checked the power rails and have +/- 19v. All a visual check has thrown up is a few possible dry joints and a scorched resistor near the output. Any help most welcome, Andy.
15th Aug 2015, 3:52 pm | #2 |
Re: Feedback TWG Function Generator
Hi Andy,
I think you dont have GND connection between bridge and circuit-find a right "place" for the loose wire. Your floating trace on scope must be hum of mains... Karl |
15th Aug 2015, 7:27 pm | #3 |
It may help to to email Feedback at Crowborough, I did this for my PFG605 last year and got the full service manual emailed back to me, very helpful.
16th Aug 2015, 5:41 am | #4 |
Thank's Stephen, didn't realise FB were still in business, I'll drop them an email.
Andy.
