26th May 2022, 6:53 pm | #1 |
TRF radio with small B4 valve base.
Hi i have a trf 1valve radio with a 4 pin skt but the socket is around 1/3 rd the size any ideas on valve type or skt type Mick
26th May 2022, 6:59 pm | #2 |
Re: trf radio with small b4 valve bace
Maybe one of the little Hivac valves like this one ?
http://www.r-type.org/exhib/aab0169.htm Cheers Mike T
26th May 2022, 8:56 pm | #3 |
Hi thanks that is the right bace says used in min radio sets so fits the bill and the circuit will work with the pin out of the XH1.5 thank you . next question where to get one ? Mick
26th May 2022, 9:03 pm | #4 |
Re: TRF radio with small B4 valve base.
There's one here
https://www.ebay.co.uk/itm/384895873...cAAOSw60dihMiv There are a few different versions on this base and I suspect any of the triodes would work. Do a search for Hivac they do turn up Cheers Mike T
26th May 2022, 9:42 pm | #5 |
Thanks Mick
27th May 2022, 1:58 pm | #6 |
Hello,
These miniature Hivac valves were made with two different heater voltages 2 volt and 1.5 volt. So the XH1.5 has a 2 volt equivalent the XH2.0 etc.. As well as triodes there was also a screen grid valve with a top cap the XSG... . Yours Richard Last edited by Mr Moose; 27th May 2022 at 2:09 pm. |
27th May 2022, 2:23 pm | #7 |
Using the same base there were also the "Midgetron" valves made by Park Royal Scientific Co.
Park Royal Scientific was actually a bunch of Hivac staff doing a bit of 'moonlighting' - which resulted in a lawsuit... Hivac Ltd v Park Royal Scientific Instruments Ltd [1946] https://onlinelibrary.wiley.com/doi/...1946.tb01005.x
I'm the Operator of my Pocket Calculator. -Kraftwerk. Last edited by G6Tanuki; 27th May 2022 at 2:29 pm. |
