28th Feb 2019, 9:46 pm | #1 |
3.5mm Jack to Composite
I've been thinking of ways to be able to get some kind of media on my TV I realised that I could use my phone or PC, play Netflix and use a 3.5mm jack to composite cable into a VCR into the TV. This slightly worked. I have sound but no video. I tested it on a modern tv to see if it was just the VCR at fault, or perhaps the cable; I got the same result on the modern TV, audio but no video. Do headphone jacks also give out a video signal? I'm sure I've seen it done before, but could I could be wrong. If they do, how easy would it be to fix the video connections in the cable? It's a "sealed" cable. An online search has been no help I've asked on here as I don't want to ruin a decent cable (I use it for audio, too) if it is just due to the phone and PC. Thanks |
28th Feb 2019, 10:33 pm | #2 |
Re: 3.5mm Jack to Composite
Headphone jacks themselves do not have video content....why should they when they are headphone jacks? It is possible to have audio and video on a 3.5mm jack. It's a special jack with an extra connection so you have a common earth connection, two for audio (stereo) and one for composite video. Obviously the phone or PC should have a corresponding 'AV' (Audio/Video) socket.
Digital cameras usually have such an AV socket so they can be played via a TV...maybe that is where you saw it.
28th Feb 2019, 10:52 pm | #3 |
The 4th connection on a mobile phone lead is for the microphone plus a click switch
- Julian It's good here |
28th Feb 2019, 11:20 pm | #4 | ||
I also realised where I had seen that connection, the back of my Xbox 360 (I cannot use that for anything other than a couple of games now) Quote:
Thanks for your replies |
28th Feb 2019, 11:54 pm | #5 |
No, the lead for the headphones (and mic)
1st Mar 2019, 12:09 am | #6 |
Oh right, sorry.
Thanks |
1st Mar 2019, 10:41 am | #7 |
I bought a little media player offered here a few months ago. About the size of a fag packet. It plays content off an SD card and I used it extensively for a party last summer and for my Xmas mix during the festive season.
Natively it outputs HDMI but there's also an analogue output that can be selected. It has a 3.5mm jack and the matching plug has an extra ring compared with a stereo headphone jack plug. I bought a plug-to-3-phonos adaptor off Amazon and connected the yellow, red, white to the obvious places on a SCART adaptor. I found the video was actually on the red or white phono with stereo on the other 2. There seems to be no actual standard for these connections but no real problem. Graham
Half my stuff is junk - trouble is, I don't know which half! |
1st Mar 2019, 10:44 am | #8 |
Your PC might have an AV socket....it depends on what video card is fitted and how it's configured. I doubt that any phone would have an AV socket.
1st Mar 2019, 2:08 pm | #9 | |
1st Mar 2019, 2:52 pm | #10 |
Red should be audio right, white should be audio left and yellow should be composite video. That was what Philips used and as far as my experience goes, so do most other manufacturers. My cheapie video camera from Aldi uses the same colours and so does my digital still camera.
1st Mar 2019, 3:17 pm | #11 |
Checking how the tip and rings map to the three phono plugs should establish whether it is the lead or the source that is using a non-standard configuration.
1st Mar 2019, 7:23 pm | #12 |
I've got a few devices with a 3.5mm jack to 3 RCAs or scart, each with a different pinout for the jack!
1st Mar 2019, 7:58 pm | #13 |
Trial and error was easy enough - "video" coming out of one of the speakers was enough of a clue!
Graham
2nd Mar 2019, 12:12 am | #14 | |
I tried the phone charger port which i know works as I’ve seen it done before on Youtube, but I think the adaptor is only audio again Going by what Llama and Dave have said, I could possibly be using the wrong connections for that lead, I’ll give it a try tomorrow when I’m home. Thanks for your help, all. I really appreciate it |
