22nd Feb 2019, 3:43 pm | #1 |
Formula...?
Known...(antenna length) l = 24.4 metres, Lambda (wavelength) = 300 metres.
Formula in book: 2*pi*l/Lambda. My calc: = 0.511. In the book it shows....2*pi*l/Lambda = 29.3 degrees. I can figure out 29.3 degrees by another route, but not by the above formula. Maths not to good with me but can someone explain? Lawrence. |
22nd Feb 2019, 3:53 pm | #2 |
Re: Formula...?
The formula θ = 2 * π * λ / L gives you an angle in radians.
Since there are 2 * π radians in a full circle, we can convert radians to degrees by multiplying by 180 / π. 0.511 radians * 180 / π = 29.3°. EDIT: If you want θ in degrees, just use θ = 360 * λ / L.
22nd Feb 2019, 4:02 pm | #3 | |
Re: Formula...?
My alternative route mentioned in Post1 to arrive at 29.3 degrees was l(360/Lambda) Lawrence. |
22nd Feb 2019, 4:11 pm | #4 |
Re: Formula...?
What is the UNKNOWN, ie 0.511 you're calculating?
22nd Feb 2019, 4:34 pm | #5 |
Re: Formula...?
29.3 degrees and 0.511 radians are the same thing.
22nd Feb 2019, 4:34 pm | #6 |
Re: Formula...?
Good question Graham, it's part of an example calculation to do with an antenna, I should have included a link Link below to RDH4, starts near the bottom of book page 903, to be fair I've also posted the question on GVR.
Also to me there seems to be a mix up with Zo and Zi in that same example, see formula (29) and the formula given in part (a) in the calculations?: http://frank.yueksel.org/other/RCA/R...sion-Lines.pdf Lawrence. |
22nd Feb 2019, 5:36 pm | #7 |
Re: Formula...?
You're right, it doesn't. The problem is that the author isn't really interested in the angle's units. He's trying to work out Xi and for that he needs to know its cotangent. Back in the 1950's when RDH4 was written he'd have looked the cotangent up in a book of trig tables (or he'd have looked the tangent up and worked out the inverse with his slide rule). As long as he knew the angle, in whichever units the tables were in, he'd be OK. My guess is that his original text was in radians but some subeditor decided that they would standardise on degrees instead. They converted the right hand side of the equation but failed to put the 180/pi factor into the left hand side. People who work with this stuff all the time just know that 2.pi.l/lambda is really an angle and swap between degrees and radians without thinking about it.
EDIT I think you're also right about the Zo and Zi mixup. In part (a) where he works out Zi as 603 ohms he should have said that that's Zo. Just a few lines further down he says Zi is 21 - j.1070 ohms and that's correct. Cheers, GJ
http://www.ampregen.com Last edited by GrimJosef; 22nd Feb 2019 at 6:05 pm. |
22nd Feb 2019, 5:53 pm | #8 | |
Re: Formula...?
Lawrence. |
22nd Feb 2019, 6:10 pm | #9 |
Re: Formula...?
Sorry, my EDIT to my previous post may have crossed with your last query. Zo is not the same as Zi - there is a mistake in the 4th line of (a).
I have a 6th impression (1963) of RDH4 up in the loft and I've just been up to check it. This part hasn't been corrected in the main text there and there's nothing about it in the Addenda at the back. Cheers, GJ
http://www.ampregen.com |
22nd Feb 2019, 6:14 pm | #10 | |
Re: Formula...?
Lawrence. |
