9th Jul 2015, 11:37 am | #1 |
Manganin Wire
I have found a reference that said Manganin wire was sometimes used for the feedback winding in regenerative receivers to improve the smoothness of regeneration, has anyone tried it, was that ever used in a production receiver?
The reference was found in Babani's Coil Design & Construction Manual. Lawrence. |
9th Jul 2015, 12:36 pm | #2 |
Re: Manganin Wire
Presumably the same effect could be got from a small series resistor. At any rate at LF/MF.
9th Jul 2015, 12:41 pm | #3 |
Re: Manganin Wire
A bit of digging on the forum reveals that some Cossor valve superhets used resistance wire for the osc coil feedback winding on SW, I'm wondering why? Self damping?
Lawrence. |
9th Jul 2015, 1:07 pm | #4 |
Re: Manganin Wire
It's quite common to find resistors associated with superhet local-oscillator feedback-windings, particularly in cases where the osc is tuned over a large frequency-range by a large-value-swing variable capacitor. It's all to do with linearising the amount of feedback as the "Q" and coupling-factor of the osc coil changes as the L/C ratio changes. Without this, you will often find that there's rather too much feedback at one end of the capacitor's travel and not quite enough at the other!
Likewise, MF/HF superhets often have resistors across or in series with the signal-frequency tuned circuits to provide a more-uniform response across the tuning range. Must admit, the idea of combining the 'resistor' with the windings themselves by using a form of resistance-wire is one that wouldn't have occurred to me but is a rather elegant solution! |
9th Jul 2015, 5:20 pm | #5 |
Re: Manganin Wire
Unwrap a dropper resistor for some wire.
9th Jul 2015, 5:44 pm | #6 | |
Re: Manganin Wire
Lawrence. |
10th Jul 2015, 6:26 am | #7 | |
Re: Manganin Wire
MW and especially LW coils have many turns of wire, wound on more than one layer. So there is significant winding self-capacitance. And in a coupling or reaction winding this can cause self-resonance. Winding with resistance wire clobbers the Q of this, preventing funny spots across the frequency range. Naturally, you wouldn't have the main tuned winding made with resistance wire! But auxiliary windings, yes. |
10th Jul 2015, 12:40 pm | #8 |
Re: Manganin Wire
Manganin has a low temperature coefficient so maybe it had something to do with temperature stability.
Brian |
11th Jul 2015, 8:35 pm | #9 |
Re: Manganin Wire
That's probably nichrome, not manganin.
