Old 27th Feb 2006, 11:34 pm   #1
Paul Stenning
Administrator
Paul Stenning's Avatar
Default Conversion of the HMV 904 to use a 5F4 CRT
I have just received the attached PDF document from Hugo Holden who feels it will be of interest to some of you and asked for it to be posted here.
File Type: pdf CONVERSION OF THE HMV 904 TO USE A 5F4 CRT.pdf (884.9 KB, 262 views)
Paul Stenning
Paul Stenning is offline
Old 28th Feb 2006, 12:25 am   #2
Steve_McVoy
Steve_McVoy's Avatar
Default Re: Conversion of the HMV 904 to use a 5F4 CRT
5FP4s are relatively hard to find. Another tube that works well is the 5AXP4, which was the first universal test tube made in the U.S. They are easy to find and physically very similar to the 5FP4.
I used one of them to replace the CRT in our Pye 817 when the Emiscope 3/1 (not the original tube) that came with the set failed:
http://www.earlytelevision.org/pye_817.html
Steve_McVoy is offline
Old 28th Feb 2006, 9:04 am   #3
ppppenguin
ppppenguin's Avatar
Thanks for this valuable information. I have a Marconiphone 706 (= HMV 904) and thankfully the CRT is still usable. It's far from perfect but I see no reason (yet) to make the set non-original just to get rid of the ion burn and get a bit more brightness. It might be worth acquiring a 5AXP4 against the day that my CRT fails.
ppppenguin is offline
