7th Mar 2008, 10:10 am | #1 |
Restoring Painted Lettering
I have been very lucky to secure a replacement Grill for my AC97 and want to revive the 'MEDIUM WAVES/LONG WAVES' lettering, which is impressed in the grill face (picture attached). Does anyone have any experience/advice on the best way to do this sort of thing?
Clearly some painting is required, but what’s the best type and is it better to try to carefully paint in the indent or just slap it on and polish off the excess when it is dry? My existing damaged grill has better lettering which is quite brown/cream in colour. I wonder if it was always that colour or whether it was originally white? As usual I am sure the is an expert ‘lettering restorer’ out there! Thanks in anticipation. Chris
7th Mar 2008, 10:47 am | #2 |
Re: Restoring Painted Lettering
You used to be able to buy the wax-type "paint" that was used to fill in the lettering of AVO's and similar faceplates, but I doubt that it is still available.
However, some time ago I did tidy up the front of an AVO using a white wax crayon, of the type that kiddies use. Rub in, carefully wipe of surplus, and polish. Looked as good as new. I am sure there must be better ways, and no doubt someone will know what they are. |
7th Mar 2008, 11:09 am | #3 |
I have used old Humbrol enamel paint, which has thickened somewhat in the tin. Clean the engraving with a toothbrush and white spirit, let it dry thoroughly, fill the engraving with the enamel, let it dry for half an hour, and then carefully wipe the surface. The drying time is fairly important - not long enough and you will lift the paint out of the engraving, but too long and you won't be able to clean any surplus paint off the surface.
Have a practice with something else, but be prepared to exercise your patience! |
7th Mar 2008, 11:28 am | #4 |
Thanks for the advice. I am sure patience will be required -I think I will wait for one of those 'when I am in the mood' times - usually a Sunday!
The crayon/wax is an interesting idea - I wonder if that was how it was done originally? In large production there must have been an easy and efficient way to do it. I am still wondering about the colour. Was it white originally? Thanks Chris
7th Mar 2008, 12:07 pm | #5 | |
David |
7th Mar 2008, 12:26 pm | #6 |
There is a photograph of an AC97 via the link at the top of this page. The lettering appears to be white, but it's unclear if this was original or just an assumption on the part of the restorer.
I also found one colour picture, in a book, of the AC97 version with ivory knobs, trim etc. Although unclear, it appears to have lettering colour matched to the respective band colours on the tuning scale. This raises the further question of whether the brown cabinet plus white lettering is original, or if the lettering was colour coded on all models regardless of trim/knob colour. |
7th Mar 2008, 1:52 pm | #7 |
I just mentioned this topic to a pal whose hobby is restoring clocks.
He tells me that some old clocks used a wax filler, that "is the same as used to be used on electronics equipment for filling lettering". Apparently it is still available from suppliers to the clock/watch trade. He suggested HS Walsh, of Beckenham, who used to stock it, and may still do so. |
7th Mar 2008, 3:46 pm | #8 |
Thanks for all your help so far. I do feel that the wax filler must have been the way it was done in production. I can't see how else it would be possible to produce large runs. I have spoken to HS Walsh and found some product on this link:http://www.hswalsh.com/items.aspx?c=588
The lady I spoke to suggested the hard wax, but the website says that it is only for metal. The soft wax is available in a good range of colours including white and gold. Has anyone actually used this on Bakelite?
7th Mar 2008, 4:26 pm | #9 |
See here for more definitive advice from the forum experts:
https://www.vintage-radio.net/forum/...=avo+lettering and here: https://www.vintage-radio.net/forum/...=avo+lettering Nick. |
7th Mar 2008, 4:46 pm | #10 |
Chris
It may be worth experimenting with Markal paint sticks, which apply like crayon, but harden like paint. These are available from Tooled-Up.com and should be available from local industrial tool factors. HTH Edward |
7th Mar 2008, 5:38 pm | #11 |
Thanks to everyone. I will let you know how I get on! Chris
7th Mar 2008, 5:48 pm | #12 |
I've used little Humbrol paint pots too. When dry it will polish off. Try furnture polish (there seems to be a gentle solvent in most that will remove the excess paint if you just press over the paint with your finger leaving a thin smear across the raised bakelite) and/or use Brasso/Bakobrite to remove excess.
You seem to have quite deeply embossed mouldings so should leave a fairly good result. One thing to watch for; if there are any nearby scratches, the paint can smear into those and is difficult to remove, so beware! Ian |
7th Mar 2008, 6:04 pm | #13 | |
No good for white lettering, either! The links in Nick's post are the way to go.
Mike. |
10th Mar 2008, 8:23 pm | #14 |
As part of my quest to get the right colour for the lettering I have borrowed a microscope with the idea of removing a bit of the existing lettering and seeing what colour it is underneath. With a careful scrape with a cocktail stick and a long peer down the lens of the microscope I discovered ... well not a lot really, but there is certainly no sign of any white. The colour was the sort of earwax shade of brown, but much closer to a gold/bronze than a white or cream. I have a hunch that the lettering was gold to match the speaker cloth. Does that make sense to anyone, or ring any bells??
Thanks to everybody who has posted a reply. I really appreciate the support and it makes me feel a little less odd to know there are others who want to bring back to life a little bit of history.
