Old 22nd Feb 2021, 1:04 am   #1
non-entity
Thumbs down Finding old ISDN PRI terminals?
So I'm trying to purchase some ISDN PRI phones. Preferably for E1/EuroISDN networks, but I can't seem to find any. I've been googling for days and all I can seem to find are ISDN BRI phones and VOIP systems. The only PRI related products I can find for sale are trunking cards.
Did anyone actually make PRI/E1 terminals. I have a few old H.320 videoconferencing phones, but they utilize strange interfaces and it will require a lot more research / work to get them working. Ideal I'd like some simpler PRI phones for this project to play with? Did such phones ever exist? Where can I purchase them or at least what manufacturers should I look for?
non-entity is offline   Reply With Quote
Old 22nd Feb 2021, 9:34 am   #2
cmjones01
Default Re: Finding old ISDN PRI terminals?
The only PRI terminal I've ever encountered was a card in a Cisco router, used to support multiple simultaneous dial-up internet connections. It was useful because it supported V.110 rate adaption, which enabled fully-digital connections from GSM mobile phones. I remember very well that from pressing "connect" on the phone to having a fully configured, working mobile internet connection (albeit at 9600 baud) took 6 seconds. Pretty impressive, even today.
Otherwise PRI connections tended to go to the telephone exchange in the building, not to individual phones.
Chris
cmjones01 is offline   Reply With Quote
Old 22nd Feb 2021, 2:44 pm   #3
non-entity
Thanks, that sounds about right. I ended up doing some more research late last night and it seems like a typical config was to have different PBX's (BRI, IP, analog, etc.) connected to a central PRI switch, along with serial terminals (mostly V,35 or RS449, in fact the H.320 videophones I mention use one of the two)
Old 23rd Feb 2021, 6:47 pm   #4
Yes I've only come across ISDN PRI stuff in 'commercial' gear - PBX and what in the 1990s was expensive Corporate-quality videoconferencing.
It was a bit-of-a-thing a couple of decades back as a way to replace a 'snake' of analog copper lines into a small-business or a radio-station but they generally got decommissioned [along with the 2b+d basic 64K ISDN circuits to 'outlier' studios] once "Metro Ethernet" became cheap.
Old 23rd Feb 2021, 7:44 pm   #5
Sparks
I seem to remember ISDN was something that Canford Audio were pushing more than twenty years ago. One of its applications was enabling stay-at-home radio broadcasters the means to connect their home studio to the appropriate 'hub' of whichever radio station they were on that day.
Sparks is offline   Reply With Quote
Old 23rd Feb 2021, 8:44 pm   #6
Yes what Canford was pushing was "Basic Rate" ISDN: two separate 64Kbit/sec channels (56Kbit/sec in the US) and a background 16Kbit/sec 'data' channel. Perfect for providing "CD Quality" digital audio between a home-studio and the actual transmitter-infrastructure. The likes of ClassicFM could not have launched without it!.
"PRI" - Primary Rate Interface - ISDN was much heavier-duty: you got a 2.048Mbit/sec pipe [1.536Mbit/sec in the US] channel that could be subdivided to provide loads of separate voice-quality audio channels [for speech-phones] or multiple sub-channels could be 'aggregated' to provide something like 320Kbits/second which was just-about-adequate for videoconferencing.
As noted upthread, this was generally done using 'professional'-grade hardware: I remember some of the Cisco Call-Manager gear from the last-century came with options for PRI cards, and Codian also offered a range of hardware-codecs that could rate-translate between popular US and UK videoconferencing bit-rates.
Old 25th Apr 2021, 2:44 am   #7
jimjim1
Polycom HDX 7000 has or is available with a PRI port.
jimjim1 is offline   Reply With Quote
Old 25th Apr 2021, 3:30 am   #8
jimjim1
Network interfaces included on each Tandberg 6000 are: IP (for H.323 connections), T1/PRI/E1, V.35, and 6 BRI S/T connections (for use in H.320 mode).
Old 26th Apr 2021, 7:32 pm   #9
dagskarlsen
dagskarlsen's Avatar
Cleaning up at job we will probably throw out an ISDN pax and 4 isdn adapters. (But it is in Norway) I s that actually interesting so may I try to get it out for the cost of the postage to you.
Name:	2021-04-20 07.40.04.jpg
dagskarlsen is offline   Reply With Quote
Old 26th Apr 2021, 7:34 pm   #10
dagskarlsen
One more picture:
Name:	2021-04-14 08.10.48.jpg
