27th Jun 2020, 12:04 pm | #1 |
GEC 5639 Tone Correction Capacitors.
Does anyone know the working voltages of the tone correction capacitors C21 & C22?
Something in the back of my mind says they should be higher than 'normal' and I would like to get hold of them before fitting them! The ones in my set are very black and impossible to read - see picture. My set is missing the bottom cover and, if possible, I would also really appreciate a picture of what the original cover looks like. Kind regards John |
27th Jun 2020, 12:13 pm | #2 |
Re: GEC 5639 Tone Caps
Can you please explain "Tone caps" ?
I can see three new electrolytics rather poorly fitted. I don't know what "tone" caps you may be asking about. There is ONE sad looking paper waxy that I would remove on sight. That's about all I can see. Joe |
27th Jun 2020, 12:31 pm | #3 |
Re: GEC 5639 Tone Correction Capacitors.
The OP meant Tone Correction Capacitors.
Thread title updated.
27th Jun 2020, 12:36 pm | #4 |
Just had a glance at the service sheet for the GEC BC5639. C21 is a 0.0015uf cap and C22 is 0.05uf cap. Theres no working voltage rating given on the trader sheet but as they're both waxies I'd just replace them them with 630v axial poly caps. You could possibly get away with 400v rated caps in those positions but would recommend going with 630v to be on the safe side.
Thanks, Peter
BVWS and BVWTM member |
27th Jun 2020, 12:38 pm | #5 | |
poppydog |
27th Jun 2020, 12:39 pm | #6 |
The tone correction cap across the output transformer primary is normally rated at 1kV, though you can probably get away with a lower rating if using modern plastic film caps with self healing characteristics. Other tone caps just need to be rated at the HT voltage.
27th Jun 2020, 12:59 pm | #7 |
Don't forget to disconnect the original HT filter capacitor if those new ones are to be left in circuit.
The HT filter resistor looks as though it's had a hard life at some point. Lawrence. Last edited by ms660; 27th Jun 2020 at 1:20 pm. Reason: correction |
27th Jun 2020, 1:09 pm | #8 | ||
I would solder each capacitor direct to the solder tags, and strap the caps together to help stop them vibrating. I would also strap the single capacitor down as well to stop it vibrating and breaking the wires or cracking the solder.. Mike |
27th Jun 2020, 2:24 pm | #9 |
I'd also strongly recommend slipping on some red sleeving to cover the live wires to the replacement caps - otherwise, it's all too easy to get a belt when you are poking about with meter probes etc.
27th Jun 2020, 2:27 pm | #10 |
Certainly a 1000V as stated or even 1500 V across the primary output transformer.
