28th Feb 2015, 1:27 pm | #1 |
R53 Broken Bulb
I have an R53 thermistor but unfortunately the bulb is broken - will that affect its performance?
28th Feb 2015, 1:46 pm | #2 |
Re: R53 Broken Bulb
Severely, I'm afraid.
It is a fastish-responding device for operation at low power levels and that means it has to be in vacuum. They're getting rather hard to find. David
28th Feb 2015, 5:59 pm | #3 |
Re: R53 Broken Bulb
I thought that might be the case David. Thank goodness I have another one.
Cheers, Jim |
28th Feb 2015, 7:10 pm | #4 |
Re: R53 Broken Bulb
This sounds like an opportunity for some comparative testing ..... !
28th Feb 2015, 7:13 pm | #5 |
Re: R53 Broken Bulb
Vacuum filled or gas filled? I thought that CO2 filling was used, with its high thermal conductivity.
Of course I could be confusing things with the old Cambridge gas analyser! Les. |
28th Feb 2015, 8:14 pm | #6 |
Re: R53 Broken Bulb
High thermal conductivity would slow its response rather a lot?
Regards, Richard, BVWS member |
28th Feb 2015, 9:09 pm | #7 |
Re: R53 Broken Bulb
It's the combination of fast-ish response and operation at low levels. In vacuo heat loss will be by mounting wires and radiation Stefan's constant says radiative power is proportional to Kelvins to the fourth power., so the solution seems to be a tiny bead running hot on low power input. If it's not actual vacuum, it must be very low pressure inert gas.
