Old 4th Aug 2020, 9:39 am   #1
zenitht
Default Ekco U29?
Hi - I'm looking for a bit of advice please. I just bought a U29 which I knew was an Export set owing to the 2 Short Wavebands.
What I had not expected to see, was 5 valves.
I check the internet and could only find a U29T but, that still has 4 valves
Any thoughts would be greatly appreciated
BTW - the missing valve in the picture (I think) is a CY31
ID:	212624   Click image for larger version
zenitht is offline
Old 4th Aug 2020, 10:19 am   #2
ms660
ms660's Avatar
Default Re: EKCo U29 ?
U29X?
What's the number of the extra valve that's fitted and the numbers of the other valves?
Lawrence.
ms660 is offline
Old 4th Aug 2020, 10:41 am   #3
zenitht
Default Re: Ekco U29?
Sure. They are:-
EF39
CBL3
? 39 (red painted coating has detached)
OM10 (Cossor) connected to Tuning Condenser)
plus the missing CY31
zenitht is offline
Old 4th Aug 2020, 10:55 am   #4
ms660
ms660's Avatar
The original valves fitted to the X version were 2 x EF39, CCH35, CBL31, CY31 so far as I can make out.
Lawrence.
ms660 is offline
Old 4th Aug 2020, 11:14 am   #5
zenitht
Thumbs up Re: Ekco U29?
Hi Lawrence
Thank you very much indeed.
Best regards
Graham
zenitht is offline
Old 4th Aug 2020, 3:42 pm   #6
zenitht
I noticed that the U29X (as shown in 'Radio Radio'), has Long/Medium/Short wavebands, whereas my one (as seen in my photo) has 2 Short and 1 Medium wavebands.
Does this make a difference to the valve line-up mentioned above, please?
I only ask because I am unable to find a circuit diagram.
Thanks
zenitht is offline
Old 4th Aug 2020, 4:03 pm   #7
ms660
ms660's Avatar
In an advert I'm looking at it gives the waveband ranges as:
200 to 550 metres
35 to 100 metres
11 to 35 metres
All for 17gns in 1948 (2nd advert down in the LH column):
https://worldradiohistory.com/hd2/ID...rch=%22u29x%22
Lawrence.
ms660 is offline
