2nd Jan 2014, 9:54 pm | #1 |
Raspberry Pi Wobbulator
Hello all. Has anyone seen, or built this wobbulator? I don't have a wobbulator, and I'm looking to build one.
http://asliceofraspberrypi.blogspot....lator-kit.html
David Goodall |
3rd Jan 2014, 12:53 am | #2 |
Re: Raspberry Pi Wobbulator
It looks good, and quite sensibly done. With one of the ADI loggers for a detector, it's really a scalar network analyser and not just a wobbulator. The DDS approach allows wide down to very narrow sweeps, and the designer even shows plots of crystal responses. I think the DDS looks like an AD9850 which will clock to 125MHz,and so give normal use to about 50MHz.
I've used those parts before and they'll do very nicely. The computer will also give you digital trace storage which is much nicer for the slow sweeps needed to plot narrow filters. I'd go for it. David
3rd Jan 2014, 9:21 pm | #3 |
Thanks David. It will be fun to play with, so I shall give it a go for £40.
David Goodall |
3rd Jan 2014, 11:02 pm | #4 |
You'll need to build a well-screened multi-section attenuator to go with it to get the level down to what would suit a radio input. Working at low level stops the AGC trying to 'correct' what you're trying to see.
I buit myself spectrum analyser with a tracking generator some years ago, otherwise I might just be building one of these. David
6th Jan 2014, 7:04 pm | #5 |
I built a prototype of something similar, with microcontrollers to make a vector display on a scope, a few years ago and still use another wobbulator using an AD9851 DDS and PIC controller nicely boxed up - great fun and I still use it. I've got a pair (or maybe three) of those modules kicking around and was going to make a simple VNA - maybe I'll just crib this one - looks interesting
Dom |
9th Jan 2014, 9:32 am | #6 |
I have just built one. Early testing as yet but it looks good so far. The kit is excellent (but not for the faint-hearted - it's mostly surface mount soldering so you'll need a steady hand, a magnifier and the correct soldering iron!).
A surprise yesterday was that I got the frequency output down to 440Hz - I'll be trying to get down to about 20Hz if possible then the wobbulator will be useful as an audio amp frequency response tester! I'll update the forum as more results come in. Richard |
