31st Dec 2013, 11:35 pm | #61 |
Re: Receiver Circuit wanted
Attached is snip of A358 oscillator circuit.
If you edit out the primary of the SW coil and close S9 and S13, you get a C-L-C pi arrangement. Effectively Fernseh's sketch has the tuning capacitor and anode coupling capacitor connections to the coil transposed. Ahhh, a quick refresher courtesy of Dr Google tells me it's a Colpitts oscillator
1st Jan 2014, 12:59 pm | #62 |
Thank you: that arrangement makes sense!
Al. / Jan. 1st., 2014 // |
12th Jan 2014, 12:58 pm | #63 |
At last as promised here is my version of the S.W.2 built for the M.W. broadcast band. Strangely enough it worked first time although the reception could be improved, it might need some extra screening around the valves. I wanted to build the chassis a bit different to my usual standard aluminium box approach and it worked out very well. Not an easy set to tune in it has to be said but interesting to play with.
Mike |
12th Jan 2014, 1:19 pm | #64 |
Nice! I really like the use of school-geometry protractors as tuning dials. Construction-style is interesting too.
Aren't you worried though that putting the speaker so it points directly at the tuning-capacitors could be a cause of microphony? |
12th Jan 2014, 3:58 pm | #65 |
I must admit that I thought there might be a problem placing the speakers in such a position, but nothing ventured as they say, as it turns out it wasn't a problem.I normally build a radio then wonder where to put the speaker, there is normally no room left on the front panel, so this time I built the radio around the speaker. Done some tweaking on the coils and now reception is perfect. It now tunes 475 kHz to 1800 kHz. Glad you like the dials,came from kids geometry sets, 99 p from ALDI.
Mike |
12th Jan 2014, 5:10 pm | #66 |
Looks like a candidate for a Bulletin article to me.
12th Jan 2014, 7:32 pm | #67 | |
How easy was it to drill/countersink the protractors without them cracking? From memory of the "Helix" brand ones we had at school in the 1970s they were rather brittle. Even the thick plastic of car number-plates is prone to cracking if your drill suddenly 'bites'. [Reason I ask is that I have an idea to use a protractor as the capacitor indicator on an antenna-tuner I've built] |
13th Jan 2014, 10:04 am | #68 |
Drilling of the protractors was not a problem, perhaps these being a cheaper version than the Helix ones they where of a softer plastic, not sure. The only precaution I took was to drill a very small hole to start,1 mm then go up in 1/2 mm stages to 6.5mm for the spindle hole.
Mike |
