11th May 2018, 5:56 pm | #1 |
DAF 92. Which sets used it?
Hi
Does anyone know please which valve portables used this valve ? Has anyone used a daf 91 instead ( the connections would need changing ) Cheers Pete |
11th May 2018, 6:36 pm | #2 |
Re: DAF 92 which sets used it
Very few if you check it on the radiomuseum site, and I suspect the 2 UK uses are not radios but direction finders.
11th May 2018, 7:01 pm | #3 |
There doesn't seem to be a comprehensive data sheet for the DAF92 on the web but there is for the equivalent valve the 1U5.
You should be able to judge the suitability of the DAF91 as a substitute for your application by comparing the data for the DAF91 with that for the 1U5. |
12th May 2018, 8:43 pm | #4 |
Re: DAF 92. Which sets used it?
I have now installed a DAF91 ( only needed 3 pins changing on the valve base )
Works fine ! |
12th May 2018, 9:11 pm | #5 |
What is it used in? Just curious.
12th May 2018, 10:13 pm | #6 |
An American Sylvania 4 valve battery portable radio
13th May 2018, 12:36 am | #7 |
Thanks Pete.
13th May 2018, 9:14 am | #8 |
Presumably that would have been built with the 1U5?
13th May 2018, 9:38 am | #9 |
Almost certainly, the 1U5 was an American valve, the DAF92 European.
A search on Radiomuseum for equipment using the 1U5 produced 500 results (the site's search result limit) of which 340 were manufactured in the USA. A similar search for the DAF92 produced only 4 results for the whole world! Only 2 were radio sets, the other 2 were direction finding receivers. |
13th May 2018, 10:24 am | #10 |
Yes the original was a 1U5 (o/c heater )
