Old 6th Feb 2006, 12:16 pm   #1
Giulio Maiocco
Giulio Maiocco's Avatar
Default Valve RF modulator
Hi all,
I decided to try to trace a schematic of an all valves RF modulator to feed my little collection of TVs with a DVD player with the Italian standard.
For now I have "completed" the sound section using a reactance modulator to get the required FM modulation, but I have only traced a part of the video section, as I don't exactly know how to get the required 5MHz bandwidth and how to input the video signal to the video output stage. I have used the frequency multipliers both on the sound and video sections.
Please could some good soul tell me if I'm on the right way and the modifications I should do to have a reasonably good RF modulator?
Best regards
Giulio Maiocco
Giulio Maiocco is offline
Old 6th Feb 2006, 1:00 pm   #2
oldeurope
oldeurope's Avatar
Default Re: Valve RF modulator
please explain me your sound preemphasis, I can not see it.
In the vision section I can not see your vision input.
You need a DC restorer and a limiter to make sure that the vision
level never goes over 100%.
Oscillators on the output frequency are the better solution because
these multipler stages are noisy.
Your output voltage should be 2mV =66dBuV
Maybe a quasi parallel sound solution is better here because
most sets are intercarrier sound.
Kind regards
Darius
oldeurope is offline
Old 6th Feb 2006, 1:19 pm   #3
Giulio Maiocco
Hi Darius,
Well, I am about to show my ignorance, but how can I do the sound preemphasis, my design is only a rough idea of the work involved, so is susceptible of wide changes. The same applies to the vision system, the problem is where should I inject the video signal and how? Does it needs some other stages ( sync separator or ..)? I have only restored a couple of TV sets, so I'm still learning, be patient, please. What is a good schematic for a DC restorer I could "copy" into my design. OK for the oscillators at the output frequency, I have read about the noise on a book I have a couple of years ago, but I forgot it until you mentioned. If we don't consider the preemphasis on the audio system, the reactance modulator in my schematic is a good method to have FM modulation in this application? If not, please could you suggest a better one?
Thanks
Giulio Maiocco
Old 7th Feb 2006, 8:38 am   #4
Sean Williams
Sean Williams's Avatar
Your Ideas of frequency multiplication are interesting, and it does mean that you can build a more stable oscillator, of course a lot more stages! - I think with FM you will need the low starting frequency to get the correct deviation.
I really wonder if you need to use a valve such as a 6CL6 - I am sure that the EF80 would be fine throughout - you are not building a broadcast station
Will watch this thread with interest, and offer any help I can, although my knowledge of Television modulator design is very little!
Sean
Sean Williams is offline
Old 7th Feb 2006, 11:04 am   #5
Giulio Maiocco
Hello Sean,
I really appreciate your input, two minds are better than one, especially after you know that my brain is already "burned out"... . I also am convinced that a lower frequency oscillator in conjunction with a frequency multiplier means a better stability and, in the case of the audio modulator, is the only method for a reactance modulator to work well.. I only need to know how to do a sound preemphasis (50uS) and then I could start to experiment with the audio section. The video section is another "bad beast" to finish and I know I need a lot of help to have it working. A 6CL6 is probably not needed as output stage,I could eventually reduce the screen grid voltage to regulate the output power, but it is needed as reactance modulator, I have a schematic that uses this valve. This RF modulator is a lot of work, but I like challenges. Don't worry about your "little knowledge of Television modulator design", I'm just a beginner, but I like to learn, you bet!!
My English is poor, but I hope you can understand what I wrote
Any input or question is welcome
Best regards
Giulio Maiocco
Old 7th Feb 2006, 1:38 pm   #6
Ed_Dinning
Hi Giulio, Pre or De emphasis is basically a tone control circuit that gives a lift or cut to part of the frequency spectrum, often to reduce transmission bandwidth. The reverse process is carried out in the receiver to correct the signal. It is typically carried out wit just and R & a C, or possibly 2 sets.
This was also done on records.
HTH Ed
Ed_Dinning is offline
Old 7th Feb 2006, 2:40 pm   #7
Giulio Maiocco
Hi Ed,
That's interesting, I thought that it was more difficult, so, if I place a parallel RC network in series to the audio input (between the hot terminal of the input and 6CL6's grid leak resistor), with R=10KOhm and C=5000pF, and changing the value of the capacitor across the audio input, I should be set.
Please correct me if I'm wrong
Ed, as always you are very helpful and willing to share your ideas with other people, this is very appreciated!!
Best regards
Giulio Maiocco
Old 7th Feb 2006, 3:48 pm   #8
oldeurope
oldeurope's Avatar
Smile Re: Valve RF modulator
Hi Giulio, it is a bit more difficult than you think.
I made a schematic for you that shows a stand alone preemphasis stage.
Often parts of the reactance stage and preveous stages are combinned
with it and makes it easier.
Hi Ed, the preemphasis makes more bandwidth but less noise.
Please note that a level indicator for +-50KHz comes after(!) the
preemphasis.
Kind regards
Darius
Old 7th Feb 2006, 10:29 pm   #9
Ed_Dinning
Hi Gents, my remarks were more directed to the sound side of things as it is relatively easy there. It is sometimes necessary to boost part of a signal instead of attenuating the "opposite" part of it. This usually calls for an amplifier with frequency selective fedback. The traditionalists prefer passive feedback as it adds much less noise.
Ed
Old 7th Feb 2006, 10:55 pm   #10
Giulio Maiocco
Hi Darius,
Thank you for your schematic, I owe you a favor . Preemphasis circuit excluded, has my sound section schematic a minimal chance to work as is? I think that the reactance modulator should be fine as drawn on the schematic, I mean we shouldn't be too far off? It certainly will need some tweaking as I don't think it will be perfect on the first power up, but we can make it work... Now I can prototype the sound section and see (or better...hear) how it acts up. I have still big problems to figure how to correctly do the video section, but this another story for now.
Hi Ed,
Your remarks are readily comprehensive, the audio field is simpler for me because I love vintage Hi-Fi systems, especially the English ones!!
Old 8th Feb 2006, 12:35 am   #11
Steve_McVoy
Steve_McVoy's Avatar
Does anyone know the pre-emphasis used in the audio of the 405 line standard? Was it the same before and after the war?
Steve_McVoy is offline
Old 8th Feb 2006, 8:40 am   #12
oldeurope
oldeurope's Avatar
Good morning Steve, preemphasis is ony used with FM.
Because of the changing modulation index with the frequency.
405 AM don't has it.
The biggest disadvantage of preemphasis is you can not transmit
high frequencys with full audio level. With he 75us used stateside this
effect is strong. To get up to 16KHz with a resonable audio level
We are gone to 50us here.
I compared all the advantages and disadvantages of AM and FM.
My conclusion is that AM is the better choise. I think this is why the
french used AM in 819. I am very sureprised about the sound quality
of my 405 sets. Normally you expect medium wafe quality if you hear
AM- sound.
And in the film TV is here again at the beginning they say :
"... the high quality sound for which TV sound is known..."
Kind regards
Darius
