Old 27th May 2008, 3:41 pm   #1
neil29
neil29's Avatar
Default sony betamax modulator.
Hi all. could someone let me know the voltage these units that ive removed from some C5s C7s actually work at. as i did not think to check before dismantling the machines..cheers neil.
neil29 is offline
Old 27th May 2008, 4:24 pm   #2
HamishBoxer
HamishBoxer's Avatar
Default Re: sony betamax modulator.
12 volts as far as i know
HamishBoxer is online now
Old 3rd Jun 2008, 2:30 pm   #3
neil29
neil29's Avatar
Thanks. thats what i thought. only when connected to a tv set i cant seem to get it tuned in properly,also there is quite a loud buzz. does anyone have any ideas..cheers neil.
neil29 is offline
Old 3rd Jun 2008, 3:32 pm   #4
Steve_P
Steve_P's Avatar
What model did it come out of?
Anyway, get a variable power supply and ramp it up slowly. That way you'll find a voltage it works at.
Anyway, tune the TV to the unit on Black Level and Silence. Then put the video in but again ramp it up slowly. That way you'll find it's best level. It might not be terminated of course. 75 Ohms at a guess.
Are you sure it's a UK standard modulator.
Cheers,
Steve P.
Steve_P is offline
Old 3rd Jun 2008, 4:15 pm   #5
neil29
neil29's Avatar
Steve. the modulators came out of some sony C5s,C7s.so they should be ok?. and when there is no video input (at black level) its fine but when switched on the picture is overbright with that loud buzz...cheers neil.
neil29 is offline
Old 3rd Jun 2008, 4:17 pm   #6
Steve_P
Steve_P's Avatar
At a guess, not terminated. 75 Ohm resistor across the I/P should do.
Cheers,
Steve P.
Steve_P is offline
Old 3rd Jun 2008, 4:21 pm   #7
neil29
neil29's Avatar
Ok steve ill try that. thanks neil.
neil29 is offline
