23rd Sep 2014, 8:57 pm | #1 |
Panasonic NV-MV20
Hi all, have a problem with this vcr, one of the newer types.
It had a leaky capacitor so this was replaced and it just hasn't run properly since. It accepts a tape but immediately laces up and begins running. The counter seems to be going too fast almost as tho the recorder is stuck in picture cue, when it is doing this none of the functions respond, not even eject. Even turning into standby it keeps on running and the only way to stop is to unplug the unit Does anyone have any insight to the issue? Thanks, Andy |
23rd Sep 2014, 10:18 pm | #2 |
Re: Panasonic NV-MV20
Only item I can offer is did you clean the PCB of all the leaked electrolyte and check that it as not rotted any other components/leads etc.
Frank |
23rd Sep 2014, 10:31 pm | #3 |
I will second that and hope the eprom etc has not been scrambled.
23rd Sep 2014, 11:40 pm | #4 |
It was in the power supply section but it's the modern type recorder with one single board. There was no leakage onto the board thankfully, it had only just started out of the top of the capacitor so I managed to remove it and replace it before any damage was done to the board.
On a very rare occasion tape speed does slow and playback can be achieved but then it goes back to normal once stopped. |
23rd Sep 2014, 11:52 pm | #5 |
If the capacitor was bulged enough to split the top, I'd replace all the others of the same make/type in the PSU at least.
23rd Sep 2014, 11:58 pm | #6 |
Can you confirm that the lid is on - these symptoms are exactly like when outside light gets to the PSU.
24th Sep 2014, 11:48 am | #7 |
Yes second that, i have been caught out on vcr's when i used to service them for a living because my bright bench light was triggering the tape end sensors making it think it was on the leader section and going into a slow fast forward (if that makes sense).
Try it with the lid on |
24th Sep 2014, 12:55 pm | #8 |
Panasonic K series come to mind for that trick.
26th Sep 2014, 8:22 pm | #9 |
Just a little update, feel a little daft admitting but it was in fact the light getting in due to the lid not being refitted after the capacitor replacement. Lid now refitted and all tested perfect
Thanks for the help guys |
