Old 21st May 2024, 9:15 pm   #1
daveone23
Default RCA WV-54A VTVM issues. (Actually a WV-65A)
When ever I turn this machine on the meter pegs. None of the controls do anything. Where should I start looking?
daveone23 is offline   Reply With Quote
Old 22nd May 2024, 12:12 am   #2
Silicon
Default Re: RCA WV-54A VTVM issues.
Check the continuity of the tube heaters and replace any paper capacitors.
Do you have the original probe lead?
Silicon is offline   Reply With Quote
Old 22nd May 2024, 1:54 am   #3
daveone23
Probes are not original but it does it without probes. They are
Simple probes, nothing unusual. I will test the valves.
Old 22nd May 2024, 7:13 pm   #4
Silicon
Some VTVM have a 1M Ohm resistor built into the probe lead.
It won't cause the swing to full scale but it will affect the calibration.
To avoid damage to the moving coil meter you could replace it with a matching resistance and then monitor the voltage across it.
When you start to fault-find the circuit set the selector switch to measure 1,000V.
Compare the voltages at the anode (plate) of each valve (tube).
Old 23rd May 2024, 8:03 am   #5
stuarth
The schematic in post 1 shows a battery valve (tube) circuit with a seperate filament cell and power switch for each valve of the long tail pair.
A poor cell or a dirty contact to either valve filament would cause enough unbalance to peg the meter.
However, the schematic is for a WV-65A, the thread title is WV-54A.....
If the actual instrument uses 2 seperate valves for the long tail pair rather than the more usual double valve, then you can quite quickly see if the problem is a valve by swapping them round, if you have a faulty valve, then with them swapped sound, the meter should peg to the other end stop.
Stuart
stuarth is offline   Reply With Quote
Old 23rd May 2024, 2:46 pm   #6
daveone23
It's a WV-65A. Title is a typo. Is there a way to correct that? I found out the valves are bad so I am in the process of buying new ones.
Old 23rd May 2024, 3:36 pm   #7
Craig Sawyers
Craig Sawyers's Avatar
Introduced in early 1948. What are you using for batteries? There are two 1.5V cells each supplying 0.1A to each heater. There are 2 x 45V ones in series to supply the anodes (plates). And another two 1.5V cells in series for the resistance measuring function.
Craig
Doomed for a certain term to walk the night
Craig Sawyers is online now   Reply With Quote
Old 23rd May 2024, 3:52 pm   #8
daveone23
Default Re:RCA WV-54A VTVM issues. (Actually a WV-65A)
I stacked 9v batteries for the 90v and used the stock holders for the 1.5 supplies
