Old 18th Jan 2019, 5:20 pm   #1
ITAM805
ITAM805's Avatar
Default Fuse rating
I was given a batch of 1.1/4" fuses, they are voltage rated on the end caps as 125V or 250V, but the current rating is odd.
The 250V reads 'S MDL 8/10' and the 125V 'SS MDX 6.1/4'. What are they anti-surge, slow blow?
Many thanks
ITAM805 is offline
Old 18th Jan 2019, 5:48 pm   #2
Default Re: Fuse rating
Those are Bussmann time-delay fuses - have a look at:
http://www.cooperindustries.com/cont...nicfuses3.html
and http://www.cooperindustries.com/cont..._MDL_MDL-V.pdf
Old 18th Jan 2019, 5:57 pm   #3
ITAM805
ITAM805's Avatar
Many thanks G6, that's them
ITAM805 is offline
Old 18th Jan 2019, 6:47 pm   #4
snowman_al
snowman_al's Avatar
If you have not guessed already, they are 800mA (8/10A) and 6.25 Amp (6 1/4A) That is the Americans for you ;-)
They are called 'dual element' fuses, I think the idea is for the solder to melt on prolonged over current. Then the spring pulls the two halves apart.
Alan
snowman_al is offline
Old 21st Jan 2019, 2:29 pm   #5
ITAM805
ITAM805's Avatar
Thanks for the info Alan. I did wonder if the 6 1/4 was 6.25A but not the 8/10A, not having dealt in fractions for many a long year!
ITAM805 is offline
Old 26th Jan 2019, 12:22 pm   #6
trobbins
trobbins's Avatar
Just a note that as those fuses are from USA and are UL rated, they aren't designed to operate continuously above 80% of rating. In contrast, IEC rated fuses are designed to operate continuously at up to 100% rating.
trobbins is offline
Old 26th Jan 2019, 1:20 pm   #7
emeritus
Interesting: I hadn't realised that rating fuses by blowing current was a UL standard. I had thought that rating fuses by blowing current rather than carrying current was peculiar to automotive fuses.
emeritus is offline
Old 26th Jan 2019, 2:07 pm   #8
ITAM805
ITAM805's Avatar
Many thanks trobbins. I had to look up 'UL rated' and didn't realise there was such a diverse range of types!
ITAM805 is offline
Old 26th Jan 2019, 2:10 pm   #9
trobbins
trobbins's Avatar
UL 284-14 is the north american standard, and is noticeably different to the IEC 60127-2 standard. For most, a fuse is really the final last gasp of protection before fire and brimstone, but for many applications a fuse may be able to be 'designed' to provide much more selectivity as to what fails and when. There is an info doc in the sticky on Fuses that goes in to some detail on that.
trobbins is offline
