Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Wanted (private buyers only, no swaps)
Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Reply
Old 13th Jul 2019, 6:29 pm   #1
Sparky67
Sparky67's Avatar
Default Coutant E7015 PSU Circuit
Hi All,
Does anyone have a cct for the Coutant E7015 PSU, or any service information on any other PSU in the same series please? This is an analogue nominal 12V / 15A unit.
Many thanks,
Martin
G4NCE
ID:	186612   Click image for larger version
Sparky67 is offline   Reply With Quote
Old 21st Jul 2019, 12:28 am   #2
Julesomega
Julesomega's Avatar
Default Re: Coutant E7015 PSU Circuit
I can't be certain which series yours belongs to, but I see it has one 2N3055. If the regulator uses a single op-amp, type uA723 it probably is from the GPE Series. Here are a couple of extracts from the little handbook.
Name:	Coutant GPE schem.JPG
ID:	187023   Click image for larger version
Name:	Coutant GPE components.JPG
- Julian
It's good here
Julesomega is offline   Reply With Quote
Old 21st Jul 2019, 8:24 pm   #3
Sparky67
Sparky67's Avatar
Thanks Julian. Apologies - my photo was intended to be of the maker's label and didn't show the pass transistor end of the box. That end is attached below, if it helps anyone identify the unit.
I am really interested in what the 'X' and 'Y' terminals on the connection tagstrip are for. My intention is to series two of these to give me 24V for testing a PRC47 and would like to know if they are involved in operating two of these in series.
Thanks again.
Martin
G4NCE
Old 22nd Jul 2019, 3:29 pm   #4
Julesomega
Julesomega's Avatar
They can be connected in series - see the manual p2
I'm not seeing terminals X and Y, all my Coutants have + and - sense terminals and P for parallel connection (see manual)
ID:	187170   Click image for larger version
Name:	Coutant GPE H-bk p2.jpg
- Julian
It's good here
Old 25th Jul 2019, 8:16 pm   #5
Sparky67
Sparky67's Avatar
This PSU has the + and - sense terminals, plus an X and Y terminal. I would be very interested to know what they are for. Any ideas?
Martin
Old 25th Jul 2019, 10:59 pm   #6
Julesomega
Julesomega's Avatar
Ah yes, clear now. Sorry I can't help
- Julian
It's good here
Old 26th Jul 2019, 7:01 pm   #7
Diabolical Artificer
Diabolical Artificer's Avatar
Telford shows as having a few Coutant Lambda PSU related manuals - http://www.telford-electronics.co.uk/manual.php?alpha=c Looking for Lamda rather than Coutant may give you a lead.
Andy.
Diabolical Artificer is offline   Reply With Quote
Old 29th Jul 2019, 5:13 pm   #8
Sparky67
Sparky67's Avatar
Thanks Andy. I will have a look.
Still being curious I dropped an email to TDK-Lambda, as they are now, and even their engineers were stumped. The thought is these PSUs were a special build for someone and the X Y facility was used with an option which is now lost in the mists of time.
When my ‘to-do’ list is a bit shorter I may look through the wiring looms, however as they are working OK as they are my curiosity will have to stay at the curious level for now.
Cheers,
Martin
G4NCE
Old 29th Jul 2019, 6:38 pm   #9
kalee20
I do seem to remember that at least one Coutant linear power supply had a connection to the base of the series-pass transistors. The idea was, you could connect two power supplies in parallel, and by connecting all the bases together, they would share the load equally.
The actual output voltage would be set according to whichever power supply was adjusted highest (or lowest) according to the circuit details. What happened in current limit would have been interesting, but I am sure this was taken care of.
That may account for terminal 'X' - I'm still scratching my head about 'Y'!
kalee20 is offline   Reply With Quote
Old 29th Jul 2019, 7:39 pm   #10
Alistair D
Alistair D's Avatar
One of those terminals could be a remote on/off. I have seen similar PSUs with such a facility.
Al
Alistair D is online now   Reply With Quote
Reply
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
