Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Offered (private sellers only, exact price required, no swaps)
Sets, Parts and Service Information Offered (private sellers only, exact price required, no swaps) You may announce components or sets for sale or offered free here. Private collectors only - no traders. You must include an exact price. No swaps.
Old 18th Nov 2023, 11:41 am   #1
manuals
Default 4th lot of meter movements
following on from my post last week ive now put the meters in smaller lots each box is £12 posted or £8 collected
box 13
meter 1 scale reads 0 1 2 ammeter dc 2-amp no 1 moving coil hole dia 6 5mm
meter 2 scale reads 0 .5 1.0 1.5 2 ammeter dc 2 amp no 1 hole dia 60mm
meter 3 scale reada 50 100 150 200 ammeters 200ua res 3ohm thermo couple hole dia 50mm
meter 4 scale reads 0 2 4 6 8 10 volts moving coil 100ohm hole dia 50mm
meter 5 scale reads 0 1 1.5 2 2.5 3 amperes for radio freq only thermo couple res 0.06ohm hole dia 50mm
meter 6 scale reads 0 1 2 3 amperes for radio freq only thermo couple hole dia 50mm
meter 7 scale reads 0 1 2 3 4 5 output rms volts hole dia 54mm
meter 8 scale reads 0 5 10 15 20 milliamperes model s33 hole dia 50mm
meters 9 and 10 scales read 0 5 10 15 20 25 30 milliamperes moving coil res 2.5ohm hole dia 50mm
ID:	288160   Click image for larger version
ID:	288161   Click image for larger version
ID:	288162   Click image for larger version
ID:	288163   Click image for larger version
manuals is offline   Reply With Quote
Old 18th Nov 2023, 11:42 am   #2
manuals
Default Re: 4th lot of meter movements
box 14
meter 1 scale reads 0 .5 1.0 1.5 2 ammeter dc 2 amp no 1 moving coil res .037ohm hole dia 62mm
meter 2 scale reads 0 50 100 150 200 250 ammeter 250 micro amp moving coil glass needs securing hole dia 62mm
meter 3 scale reads 0 1 2 3 4 5 ammeter 5ma no 2needle wont zero but is free moving hole dia 65mm
meter 4 scale reads 50 100 150 200 ammeter 200ua thermo couple res 3ohm hole dia 50mm
meter 5 scale reads 0.2 .4 ..8 1 thermo ammeter for radio frew only hole dia 62mm
meter 6 scale reads 100 200 300 350 ammeter hf 350ma thermo couple hole dia 50mm
meter 7 scale reads 0 20 40 60 80 100 ammeter dc 100ma moving coil hole dia 50mm
meter 8 scale reads 0 250 500 dcua hole dia 35mm
meter 9 scale reads 0 1 1.5 2 2.5 3 amperes for radio freq only thermo couple res .06ohm hole dia 50mm
meter 10 scale reads 0 5 10 15 20 25 30 milliamperes moving coil res 2.5ohm hole dia 50mm
meter 11 scale reads 0 100 200 300 400 500 ua moving coil res 100ohm hole dia 50mm
ID:	288165   Click image for larger version
ID:	288166   Click image for larger version
ID:	288167   Click image for larger version
Old 18th Nov 2023, 11:43 am   #3
manuals
box 15
meters 1 and 2 scales read 0 2 4 6 8 10 amperes moving coil res 0075ohm hole dia 88mm
meter 3 scale reads 0 20 40 60 80 100 moving coli model 702 100ua hole dia 49mm
meter 4 centre zero scale reads 75 150 225 300 either side microamperes dc hole dia 52mm
meters 5 and 6 scales read 0 1 1/5 2 2.5 3 amperes for radio freq only thermo couple res .06ohm hole dia 50mm
meter 7 scale reads 0 30 60 90 120 150 ac volts fs 150 acv hole dia 50mm
meter 8 scale reads 0 10 20 30 40 50 direct current milliamperes mofdel hs2 hole dia 52mm
meter 9 scale reads 0 5 10 15 milliamperes direct current hole dia 39mm
ID:	288169   Click image for larger version
ID:	288170   Click image for larger version
ID:	288171   Click image for larger version
ID:	288172   Click image for larger version
Old 18th Nov 2023, 11:44 am   #4
manuals
box 16
meter 1 scale reads 0 2 4 6 8 10 amperes moving coil res .0075ohm hole dial 88mm
meter 2 scale reads 0 50 100 150 dc milliamperes model 305 hole dia 67mm
meter 3 scale reads 0 200 500 600 800 1000 microamperes moving coil hole dia 62mm
meter 4 scale reads 0 10 20 30 milliamperes moving coil hole dia 63mm
meters 5 and 6 scales read 0 5 10 15 20 ammeter dc 0-20 milliamps moving coil hole dia 65mm
meters 7 and 8 scales read 0 1 1.5 2 2.5 3 amperes for radio freq only thermo couple res .06ohm hole dia 50mm
meter 9 scale reads 0 100 200 300 400 500 micro amperes moving coil hole dia 50mm
ID:	288174   Click image for larger version
ID:	288175   Click image for larger version
ID:	288176   Click image for larger version
ID:	288177   Click image for larger version
Old 18th Nov 2023, 1:55 pm   #5
mickm3for
Hi can I go for box 16 as well thank you.
Will PM.
mickm3for is offline   Reply With Quote
Old 18th Nov 2023, 3:10 pm   #6
manuals
box 16 now sold thanks
Old 20th Nov 2023, 10:24 pm   #7
Mark James
Is box 13 still available? I will PM.
Mark
Mark James is offline   Reply With Quote
