12th Jul 2021, 1:29 pm | #1 |
Philips Reel to Reel Model Suffix Numbers Meanings
Does anybody have any information as to the meanings of the various suffix numbers sometimes present on these recorders after the model number.
I am particularly interested to find out the difference between an EL 3549A/00 and an EL 3549A/15 The 00 and 15 seem quite common suffix numbers on a wide range of Philips recorders but there are also others. David |
12th Jul 2021, 2:11 pm | #2 |
Re: Philips Reel to Reel Model Suffix Numbers Meanings
Those forward slash numbers related to the place of manufacture.
12th Jul 2021, 2:43 pm | #3 |
/00 is Eindhoven and /15 is UK, if memory serves.
12th Jul 2021, 7:48 pm | #4 |
Yes the /00 was usually for products made for the continent. /15 was UK but in later years they also used /05 and /25. Somewhere I might have a list of the common /xx numbers.
12th Jul 2021, 8:33 pm | #5 |
Maarten, I think he knows about Phillips model and serial numbers coding,
Regards, Alan |
13th Jul 2021, 9:22 am | #6 |
Thank you to everybody for your useful inputs, would be good to see a listing and will be interesting to hear what Maarten can add.
I see from much earlier Threads for the EL 3549, there are references to 2 versions with different rewind belt configurations, the earlier version being referenced as a WR00 David |
13th Jul 2021, 10:44 am | #7 |
WRxx are production change numbers, 00 being the first generation, 01 being the first change etc. Basically each time there was a production change, the WRxx number changed. It could be just a trifling change perhaps a cabinet molding or a circuit design change.
13th Jul 2021, 10:52 am | #8 |
Thank you Sideband that is interesting, so this must mean for example that WR00 is a separate/additional part of the model number identification from the continent build /00 ?
David |
13th Jul 2021, 12:52 pm | #9 | |
The numbers behind the - or / are part of the model number (commercial use / stock keeping unit) while the above mentioned origin, revision and date code are part of the serial number (factory and service use). The numbers behind - or /are so called 'execution numbers', indicating different specs (mostly destination market related) or aesthetics. Sometimes indicating an MKII version or different packaging. Exactly what a manufacturer would want to use to identify different models in its stock and sales channel. The reason the most common numbers (in the UK) are /00 and /15 isn't too surprising: /00 means 'specification for the general market or basic model' while /15 means 'specification for the UK market' with the difference often only the 240V mains voltage and the (absence of a) mains plug. Last edited by Maarten; 13th Jul 2021 at 1:09 pm. |
13th Jul 2021, 12:57 pm | #10 |
Very interesting! I'm working on such a list as well, I'll see how I can present it in a readable manner as the system is a bit complicated. Most important: for consumer electronics, the list was fully revised in 1980 so there are at least two different lists that don't correspond to eachother (/15 was used up to 1980, /05 from 1980 on). Tape recorders didn't fully follow the consumer electronics standard either, as a version for the US or Canada could be /60 (for 60Hz) while normal consumer electronics used numbers such as /54 (assigned to the US, no specific meaning).
18th Jul 2021, 6:56 pm | #11 |
Many thanks to Maarten for the various clarifications.
David |
