5th Jul 2021, 1:11 pm | #1 |
Perished Cable In Old Radios
Moderators please move this if in the wrong section . What cable do you use to replace perished rubber coated cable in old radios and where to buy it kind regards Bob
5th Jul 2021, 1:49 pm | #2 |
Re: Perished Cable In Old Radios
I use silicon cable from Rapid part no for black is 63-6256. Other colours are available. It states that it is single core, but in fact it is multi core. I have been using it for sometime now.
Dave |
5th Jul 2021, 2:02 pm | #3 |
By "multi core" I take it that you mean stranded, and that by "single core" they mean that there is only one conductor.
5th Jul 2021, 2:12 pm | #4 |
All colours of silicone-rubber insulated stranded cable can be bought at the NVCF (when it happens!), but the seller is a member on here.
Andy |
5th Jul 2021, 2:25 pm | #5 |
Or for shortish lengths, you can unsolder one end, remove the old wire's sleeving, thread-on new, then re-solder.
5th Jul 2021, 2:54 pm | #6 | |
https://www.vintage-radio.net/forum/member.php?u=2271 Phil sells heatproof silicon rubber insulated stranded flex (in two gauges) in several muted 'vintage' colours which strips easily look much more in keeping than gaudy PVC, apart from the obvious advantage of being heat-proof. As you are restoring a DAC90A, I've generally found the speaker wiring, the dial lamp wiring, and some of the wiring around the dropper to be in poor shape, and I guess that's why you've raised the query. Like many forum members I normally stock up from Phil's stand at the NVCF ('Retrotech') show each year, but I know that he's happy to deal with individuals by post. He regularly visits the forum (he was on today at 1300 Hrs), so if you send him a PM I'm sure he'll respond promptly. (I've not seen it available in small quantities elsewhere). Hope that helps.
5th Jul 2021, 4:08 pm | #7 |
A low cost option is to use PVC coated wires of the correct voltage rating and thickness.
If you abrade them with a Scotchbrite pad you can remove the surface shine to make them look more like rubber. |
5th Jul 2021, 7:52 pm | #8 |
Silicone-jacketed stuff is good; I've also made extensive use of the glassfibre-braided stuff typically found in old cookers; this is rated for 250V AC mains, but seems to work just fine when feeding the anode-connections of RF-power valves like the 807 and 6146 where things can be hot for long periods.
I've also used the glassfibre-braided cable for wiring around ceramic valve-sockets housing 'juicy' HT-rectifiers. |
5th Jul 2021, 8:58 pm | #9 |
You are right Dave, I should have said stranded not multicore.
6th Jul 2021, 1:40 pm | #10 |
Thanks to every one that has replied to this thread forum member SWB 18 ( Phil ) has kindly helped me out moderators please close thread
