17th Aug 2016, 11:41 am | #1 |
Repairing a Magneto Electric Machine, shock machine
I am trying to restore a Magneto Electric Machine. I will post what I am doing to share ideas, as I have seen that others here have been trying to restore similar machines.
It seemed to be in very good condition and the mechanism worked OK, but I soon discovered there was no output. This was because there was no contact between the axle and the metal contact. (Picture 2, circled in yellow) If I connect them it does have an output. I am trying to think of a way to connect them with minimal friction. I may have to change the way they are connected. The belt under the big wheel was scraping on the bottom of the box. This was because the screws attaching the frame to the box at the front and back had come loose. (Picture 3, next to the keyhole, and there is another at the back) I tightened them and I also took the strain off the screws by putting an eraser under the magnet. (Picture 4) This solved the problem. The magnet is very weak, I will try to remagnetize it. I will also need to oil it, would sewing machine oil be any good?
Lucia |
17th Aug 2016, 12:43 pm | #2 |
Re: Repairing a Magneto Electric Machine, shock machine
You could probably pep up the magnet with a few small SmCo magnet discs attached to the ends of the horseshoe.
17th Aug 2016, 4:42 pm | #3 |
Thanks, I will try that.
Lucia |
17th Aug 2016, 4:56 pm | #4 |
I have remagnetised a magnet https://www.vintage-radio.net/forum/...8&postcount=18 see the rest of the thread for details, all good fun!
17th Aug 2016, 6:34 pm | #5 |
Thanks, sounds like fun!
Lucia |
17th Aug 2016, 8:38 pm | #6 |
Hi Lucia, I couldn't easily see where you needed the sliding contact to be made, but a carbon brush out of a small motor should do the trick.
Ed |
17th Aug 2016, 11:58 pm | #7 | |
18th Aug 2016, 8:43 am | #8 |
Wow - "for nervous diseases". I'd feel even more nervous having been given a belt from that machine! Don't you just love Victorian quackery.
Nice restoration task. |
18th Aug 2016, 12:17 pm | #9 |
DIY ECT?
18th Aug 2016, 7:40 pm | #10 |
Here is a video of me trying it on myself with LEDs in series. The LEDs are in opposite directions to let the AC output through. Notice how the LEDs flashing are synchronized with my twitching. Very invigorating
https://www.youtube.com/watch?v=abD4sBRfus8
Lucia |
19th Aug 2016, 8:42 am | #11 |
What's 'ECT'?
I've remagnetised a few things like this - yes, I know it's AC and yes, it is dangerous if you don't know what you are doing:
Mike. |
19th Aug 2016, 8:51 am | #12 |
We've got one of these somewhere. What sort of voltage do they give out? I think the belt's gone in ours.
Kevin |
19th Aug 2016, 10:11 am | #13 |
ElectroConvulsive Therapy. I'll refrain from expressing my opinions on the use of this treatment in the field of mental health, but it's a modern-day hangover from these Victorian quack therapies - definitely not to be attempted at home with an electric shock machine.
19th Aug 2016, 11:09 am | #14 |
Thanks, Dave. I thought it wouldn't be H1360 speaking EBayese for 'et cetera'!
Mike. |
19th Aug 2016, 1:48 pm | #15 |
Judging by the instructions (complete with drawings!) it looks like the use was remarkably similar to a modern-day TENS machine, and not for ECT. The output also feels similar to a TENS machine.
I don't know how to measure the voltage, as it only gives little peaks of voltage with a low duty cycle.
Lucia |
19th Aug 2016, 3:41 pm | #16 |
I would agree that a TENS machine is the modern-day equivalent - albeit more controllable.
If you really want to check the output voltage, try feeding it into an oscilloscope (probably with appropriate attenuation). The voltage, as well as the frequency, will be dependent upon the speed of cranking it.
19th Aug 2016, 4:27 pm | #17 |
And to decode another acronym, TENS "transcutaneous electrical nerve stimulation", a weeny shock through the skin, fun for some I suppose.
19th Aug 2016, 4:31 pm | #18 |
TENS has proven pain-relief benefits. I'm not sure I'd call it fun, though
19th Aug 2016, 6:11 pm | #19 |
Thanks for the reminder of the TENS acronym.
I can confirm the pain-relieving effects, having suffered joint and muscle pains for most of my life. I recall having its benefits back in my school days in the 1960s - though less sophisticated than my modern machine, and not (as far as I know) called TENS back then.
21st Aug 2016, 9:49 am | #20 |
