Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Repair and Restoration Services Wanted
Repair and Restoration Services Wanted If you need someone to repair or restore equipment for you please post your request here.
Old 19th Jun 2020, 12:33 pm   #1
111Robin
Default 1970's Sun Circuit Board Test/Repair
Hi folks, first post on here as I'm having no luck at all finding anyone willing to test/repair some circuit boards I have dating from the late 70's/early 80's. I'm hoping that someone on here can either help or at least point me in the direction of someone who can. The boards are from a Sun Engine Analyser of mid 70's build date. I purchased it from an ex Sun engineer in the US who refurbishes old Sun equipment. Everything was originally working perfectly however since last winter I have been having some issues with certain functions. The trouble shooting section in the manual simply says to replace certain boards if these faults occur, ok in the 70's but not now obviously. There are two boards that may/may not have faults according to the manual. The photos below are one of these boards. Is it possible to check through the boards to determine if there are any faulty components and replace those with similar parts ?. I'm based near Aberdeen however the boards could easily be posted anywhere. Let me know your thoughts,
Thanks,
Robin
ID:	208889   Click image for larger version
ID:	208890   Click image for larger version
111Robin is offline   Reply With Quote
Old 19th Jun 2020, 2:38 pm   #2
unitelex
Default Re: 1970's Sun Circuit Board Test/Repair
Hi Robin
I will send you a PM, check your inbox
unitelex is offline   Reply With Quote
Old 19th Jun 2020, 3:25 pm   #3
111Robin
Thanks Chris, additional photo's sent as requested,
Robin
Old 22nd Jun 2020, 7:53 am   #4
111Robin
I'm still looking for assistance with this if anyone is able to help?
