3rd Apr 2018, 6:37 pm | #1 |
Unknown but working
Anyone know what this unit is? it aperars to be working thought it was a signal generator at first , but it has scale reading in ohms and micofarads mabe a capacitor tester the magic eye valve is working and the output terminals shows a sine wave varable . Had this over 30 years been in the garden shed , amazing it seams to work what ever it is.
3rd Apr 2018, 6:47 pm | #2 |
Re: Unknown but working
I imagine it's a resistor and capacitor measuring bridge. An oscillator in there would be the input to the bridge and the magic eye would be across the bridge to identify the null.
Graham
Half my stuff is junk - trouble is, I don't know which half! |
3rd Apr 2018, 7:59 pm | #3 |
It looks like a piece of home brew kit built into some ex-gov case.
There were several designs associated with PW, Radio constructor etc in the 50's. If you know the valves it may be possible to trace its origins from there. Ed |
3rd Apr 2018, 8:15 pm | #4 |
Certainly is a bitzer- Belling Lee terminals and Paignton (Paynton?) knobs, and the indicator light and connectors look MOD origin. I bet you won't ever see another one..
3rd Apr 2018, 8:56 pm | #5 |
Definitely home-brew. The scale gives it away as everything is hand-written. Yes it would be interesting to try and find the design so perhaps try to identify the valves used. Probably dates to the 50's when lots of Army Surplus gear was available.
3rd Apr 2018, 9:33 pm | #6 |
I think you are right , i put a capacitor acreoss the terminals and the magic eye closed off to about half . The Valves have typical WD ^ markings on them not checked the part numbers
3rd Apr 2018, 10:33 pm | #7 |
It does look like an AC R/C bridge.
I have got a Phillips factory made one that just does resistance but with an external decade box will also do capacitance. It has been superseded by a very posh Marconi one that I recently restored. |
