Old 6th Apr 2008, 8:35 pm   #1
russell_w_b
russell_w_b's Avatar
Default Bellset No: 20 - Brass or Black?
I have just acquired a GPO Bell-Set No:20, and was wondering what sort of finish the gongs and the switch-plate should have? One gong is copper (stamped '17'), the other brass (stamped '2A'). Both are 2 1/2" diameter. The engraved switch-plate is manufactured from brass, and has a smooth finish. I suspect that some attempt has been made to clean the metalwork in the past.
Whilst I am quite happy to clean up the brass-work and gongs, a glance at britishtelephones.com shows that the metalwork is finished in black! Now, I rather like the black with white figures (I could use the 'AVO' wax-stick technique to pick them out), but was wondering:
  • Were two versions of Bell-set No:20 available: one with brass finish, the other in black?
  • If I wish to revert to black finish, what should I use? It is obvious that the brass is smooth and not keyed, and I don't want to score the brass to get paint (or whatever) to stick to it.
What does the panel think?
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline
Old 7th Apr 2008, 12:40 pm   #2
beery
beery's Avatar
Default Re: Bellset No: 20 - Brass or Black?
Hi Russel,
the original finish was a black bronze effect. This was also used on parts of candlestick phones (not the main stem though, which was painted). The GPO never went in for polished brass.
To get the bronze effect the brass parts were copper plated and then heated up so that the copper turned to black oxide which was then lightly polished.
I have never experimented with re-plating etc.. I do know that there are phone restorers that do re-plate stuff.
Andy
beery is offline
Old 7th Apr 2008, 7:00 pm   #3
russell_w_b
Originally Posted by beery View Post
Hi Russel,
Andy
Andy,
Thanks! I guss I could experiment (I haven't had a go at such like since I was a youth), but I'd do it on a test-piece first . If it doesn't work, I shall seek out someone who can do it properly.
I have a few nickel(?) plated 2 1/2" gongs kicking around; the sort with the matte-silver finish as found in type 300's. Is it possible to copper-plate them without any pre-treatment? One of the gongs on my No:20 bell-set is pitted, and - if I could - I would replace them.
Regds,
Russell W. B.
G4YLI.
Old 12th Apr 2008, 12:12 am   #4
samthelemming
I don't know if its of any help but I heres a picture of my bell set No. 20 in totally original condition. (couldnt get a very good picture because my workbench was in the way)
samthelemming is offline
Old 12th Apr 2008, 9:42 pm   #5
russell_w_b
Very helpful; thanks! I concur that the black looks better than brass-finish (which I consider to be, well, 'brassy'...).
I see your version has a DC bell attached. Did you do it or did it come like that?
Regds,
Russell W. B.
G4YLI.
Old 13th Apr 2008, 1:55 pm   #6
samthelemming
The DC bell has always been on it, It came from a police station is all I know, i assumed they all had one, but looking at the circuit diagram I can't see it on there
Name:	bellset no20 inside.jpg
ID:	16400   Click image for larger version
Name:	circuit diagram bellset no20.jpg
