Old 13th Feb 2019, 6:08 pm   #1
Viscount
Default Leak Delta 30.
Just got hold of a Leak Delta 30 amp, all working well and sounds amazing,only prob is the on off volume control is intermittant when turned up and down. I have cleaned it with switch cleaner and it made no difference so need to change it, so details of what I need would be helpful, there appears to be no marking on the original.
Many thanks.
Viscount is offline
Old 13th Feb 2019, 6:15 pm   #2
BRASSBITS
Default Re: leak delta 30
That's strange it's usually marked on the side of the pot, have you removed it to look all round it?
BRASSBITS is offline
Old 13th Feb 2019, 6:29 pm   #3
Viscount
Default Re: Leak Delta 30.
Yes I have, some very faded markings that I can't read.
Viscount is offline
Old 13th Feb 2019, 6:46 pm   #4
RojDW48
RojDW48's Avatar
Oddly enough I have just bought one of these at an auction. Already cleaned the pots but I need to take it apart again to solve a contact issue with the phono sockets - I shall see if I can read the info on mine and get back.
'....don't go mistaking Paradise for that home across the road!' (Bob Dylan)
RojDW48 is offline
Old 13th Feb 2019, 6:48 pm   #5
ajgriff
ajgriff's Avatar
Hi-Fi Engine has the service manual. It's free to sign up if you're not already a member.
https://www.hifiengine.com/manual_li...delta-30.shtml
Alan
ajgriff is online now
Old 13th Feb 2019, 6:49 pm   #6
Why not measure it with a meter? It appears to be noisy rather than open circuit, so should give the correct value.
Keep the soldering iron hot.
Station X is offline
Old 13th Feb 2019, 7:08 pm   #7
RojDW48
RojDW48's Avatar
It appears to be 20K Log - I assume the rest is a part number? 8DB L2 AB CTS
RojDW48 is offline
Old 13th Feb 2019, 7:24 pm   #8
Viscount
OK that's great, thanks for that.
Viscount is offline
Old 13th Feb 2019, 10:15 pm   #9
LeakyGrid
I have a circuit diagram which confirms that it is 20k.
Roger
LeakyGrid is offline
Old 13th Feb 2019, 10:23 pm   #10
Michael Maurice
Michael Maurice's Avatar
If it has the on/off switch then you’ll have to get it made up.
Forum Moderator
Michael Maurice is offline
Old 14th Feb 2019, 12:20 am   #11
ajgriff
ajgriff's Avatar
The Delta 30 has an on/off switch separate from the volume control so that won't be an issue.
Alan
Old 14th Feb 2019, 5:21 pm   #12
Viscount
my delta 30 has a tandem volume with a 4 pin switch unit built into the rear of the pot,are they still available with the correct shaft length?and yes 20k seems to be correct
Viscount is offline
Old 14th Feb 2019, 5:34 pm   #13
dazzlevision
The pot in your amp was made by AB and they are still in production: https://www.blore-ed.com/series45potentiometers
They will make up custom specials.
dazzlevision is online now
Old 14th Feb 2019, 5:46 pm   #14
Viscount
thanks for that,ive contacted them and am waiting for a reply
Viscount is offline
Old 14th Feb 2019, 6:19 pm   #15
ajgriff
ajgriff's Avatar
Alan
My apologies. The Delta 30 does indeed have an on/off switch combined with the volume control. I was thinking of the Delta 70, sorry.
Alan
Old 14th Feb 2019, 8:07 pm   #16
Viscount
not a prob alan ,hopefully i can get hold of one
Viscount is offline
Old 17th Feb 2019, 9:15 pm   #17
Viscount
so yes they can supply a new unit for about 20.oo which seems good to me,will try one more attempt at cleaning it and see how it goes
Viscount is offline
Old 18th Feb 2019, 12:35 am   #18
RojDW48
RojDW48's Avatar
Worth a go - mine had similar problems but servisol cleared it. Also the grounds on the phono sockets were oxidised and working intermittently - check them too.
RojDW48 is offline
Old 20th Feb 2019, 2:56 pm   #19
Viscount
So here we are again with the Delta 30, so I've just cleaned all the pots with Servisol and cleaned the phono sockets and what a difference that has made, not a fault with any of the pots, seems to have worked better than I ever imagined.
Viscount is offline
Old 20th Feb 2019, 3:11 pm   #20
ekjdm14
Another win chalked up for Super 10 I've often found that really dirty pots can take 2 goes to get them quiet and reliable. If the first application and working the pot doesn't do it then I give them a drowning and let them sit a minute before working them back & forth.
ekjdm14 is offline
