11th Mar 2009, 11:56 am | #1 |
Oil impregnated bearings
Hi gang
I have a couple of things with motors either running slow or not running at all, unless they are given some oil. I presume these use are brass(or bronze) oil impregnated bearings(no balls visible). I believe I can restore these bearings by immersing them in hot oil. What sort of oil is suitable(3 in one, engine oil?) and approx how long should they bathe? (Never before attempted!!) Thanks Tim Mods please move if in wrong section.
11th Mar 2009, 12:09 pm | #2 |
Re: Oil impregnated bearings
11th Mar 2009, 7:44 pm | #3 |
Thanks!!
I'll have a go with machine oil. i suppose something like white spirit could be used to wash out.
11th Mar 2009, 7:56 pm | #4 |
Tim,
Yes, I would think so, although if the pores are clogged up with grease or old polymerised oil, it may not do much good. I didn't totally agree with the previous thread when it said the bush should be removed and then washed etc. These bushes are actually made slightly oversize. They achieve their 'working' size when they're pressed into the correct sized hole. The snag is you can only do it once. On the other hand I don't expect the stresses on it in a record player are very high so it probably won't make much difference if you do take it out. I'd be inclined to put a drop of Loctite on the outide when I put it back. Alan |
11th Mar 2009, 8:08 pm | #5 |
11th Mar 2009, 8:34 pm | #6 |
But then it wouldn't be pressed in would it? They're normally held in place with a hemispherical collar.
11th Mar 2009, 8:42 pm | #7 |
Ah! Yes. Sintered sleeve bearings, press-fitted into a precision hole, rather than a sintered spherical bearing held in its housing with a press-fitted diaphragm-type spring!
11th Mar 2009, 10:11 pm | #8 |
Indeed!
