Old 18th Sep 2019, 2:55 pm   #1
mikeymouse
Smile Avo 8 mk V high resist ranges u/s
Hi. I'd be very grateful if I could be pointed in the right direction with my issue. I recently purchased an Avo8 Mkv meter fitted with a miniature voltage converter (part no 6220-126). The meter was described as "appears to be working". More fool me!
On the lowest resist range, the meter zeros and works fine, however on the next two ranges, 100 and 10k, the meter needle stays at the extreme lhs and the zero pots have no effect whatsover. I have replaced the original D cell, cleaned the cell contacts and checked the fuse, all good.
Many thanks for any pointers ...
mikeymouse is offline
Old 18th Sep 2019, 4:18 pm   #2
Sinewave
Sinewave's Avatar
Default Re: Avo 8 mk V high resist ranges u/s
Hello and welcome.
Perhaps dirty switch contacts or, more likely the printed ribbon cable has a fault, which connects to the switch terminals. The Mk5 is not difficult to work on, so if the particular circuit in the ribbon is damaged, you can make point to point wiring and solder to each connection.
Here's a link to the manual which contacts schematics.
https://www.vintage-radio.net/forum/...2&d=1421628490
Avometer, vintage Fluke and Marconi collector. Also interested in vintage Yaesu and KW.
Sinewave is offline
Old 18th Sep 2019, 6:55 pm   #3
Trevor
I replaced the voltage converter module in mine with a battery this restored normal operation
Trev
Trevor is offline
Old 18th Sep 2019, 6:59 pm   #4
The Philpott
The Philpott's Avatar
Testing the output of the VC1 is done using as sensitive a voltmeter as possible, since it's designated current output is very low (90uA i think.)
Dave
The Philpott is offline
Old 18th Sep 2019, 10:14 pm   #5
Sinewave
Sinewave's Avatar
Yes, but he's missing one of the ranges covered by the 1.5v battery.
Sinewave is offline
Old 19th Sep 2019, 8:09 am   #6
mikeymouse
Thumbs up Re: Avo 8 mk V high resist ranges u/s
Many thanks to all for the responses. Anyone know where I can source spares for this model?
Old 19th Sep 2019, 10:12 am   #7
Sinewave
Sinewave's Avatar
Parts now are only available if you're lucky enough to find someone selling parts, second hand or new old stock.
However, you probably don't need any parts. Have you looked at the printed ribbon cables?
Sinewave is offline
Old 19th Sep 2019, 10:59 am   #8
mikeymouse
Will do. Many thanks
Old 22nd Sep 2019, 6:31 pm   #9
mikeymouse
Hi. Looking for more clues, if you guys can help. My Avo8 mkV is working on the lowest range. The other ranges have no response to their respective zero pots. On the 100 range, the needle goes hard rhs and stays there. On 10k the needle goes hard lhs and stays there. Full travel cw and ccw of their respective pots does absolutely nowt. I have replaced the D cell and used shorting pieces of cables soldered directly to the D cell posts and the corresponding ends are connected to VC1. The output of VC1 measured across the VC1 terminals is approx 14.8V.
Be obliged for any further suggestions.
Old 22nd Sep 2019, 9:13 pm   #10
Sinewave
Sinewave's Avatar
I can only refer you back to previous suggestions unless you've already tried - the printed ribbon cable connecting the range selection switches...
ID:	190661   Click image for larger version
Sinewave is offline
Old 23rd Sep 2019, 4:37 pm   #11
mikeymouse
Many thanks for your responses, Sinewave. I was hoping not to open up the box. From your images, as you say, dosen't look too bad to work on. That's my next step. Cheers for the assistance
