15th May 2017, 4:39 pm | #1 |
Power switch on Farnell H series PSU's?
By any miracle does anyone know if a replacement two pole, interlocked lever mains power switch is still available for the Farnell H series linear power supplies? I just bought a second H60/50 beast and although the mains switch works both toggles are snapped off (and missing...). I know from previous kind help with schematics some on here are familiar with, or owners of these ageing beasts! Thanks
Best Regards, CW. 2E0ILY |
15th May 2017, 5:47 pm | #2 |
Re: Power switch on Farnell H series PSU's?
I've never had to find a replacement for one of those but I reckon it will be proprietary type rather than custom made, so it may be possible to find one. Pity I scrapped an H30-100 last year, I think that has the same switch.
BVWS member |
15th May 2017, 7:32 pm | #3 |
they're 'hydro magnetic' circuit breakers aren't they....the type you push up to switch on?
Mouser do them. made by carlingswitch, eaton-heinemann, airpax etc http://www.farnell.com/datasheets/16...488.1494363317
Kevin Last edited by McMurdo; 15th May 2017 at 7:40 pm. Reason: added datasheet link |
17th May 2017, 1:33 pm | #4 |
Yes, they look quite similar, thanks. I now have another issue with my original one, so I have started a new thread, cheers!
