Old 23rd Feb 2021, 3:07 am   #1
Magical
Default Radiomobile 108S Alignment Issues
Hello all,
I’m trying to finish a repair on a Radiomobile 108SR N/P, which is positive earth. The owner unfortunately accidentally brushed a positive crocodile clip against the power terminal a “blew” his set. He said the radio was working fine before. On opening up the set and looking at the output amp section I found a blown track, which I repaired and I replaced two BC139 transistors. The output amp works fine and the 8 track plays well.
The problem I have is with the radio. I can get no output from the normal aerial. If I touch the component tails sticking through the circuit board just by the waveband selector I can pick up very faint signals.
Using a signal generator I can tune to get a strong output at 1600Hz. I can also tune to get a strong output on the IF at 470Hz. The problem is tuning for each of these scenarios upsets the other. Can anyone give me a pointer please?
Cheers,
Magical is offline
Old 23rd Feb 2021, 6:26 am   #2
Magical
Default Re: Radiomobile 108S Alignment Issues
Sorry, quick correction....1600kHz and 470kHz...
Magical is offline
