Old 15th Jun 2020, 4:08 pm   #1
FERNSEH
FERNSEH's Avatar
Default Philips L6X38T "Antoinette".
A discussion about a similar receiver appeared in the forum in 2008:
https://www.vintage-radio.net/forum/...ad.php?t=30757
The Philips L6X38T which is the subject of todays discussion was brought into the shop quite a long time ago. Last week I summoned up the courage to attempt to repair it.
For starters the audio amplifier needed attention. Voltages on the transistors were way out, no volts at the collector of the audio driver transistor TS9, (AC125) that turned out to be the earphone switch needing adjustment. In this set the collector of the driver transistor can be switched to the driver transformer or the earphone, it's just a matter of pressing a button at the back of the cabinet which then allows the earphone cable to be released. Press another button and the earphone lead will be re-spooled into the cabinet and the driver transformer is reconnected to the transistor.
That part put right still no activity from the loudspeaker, more contact troubles. The extension speaker socket has contacts which break when the external speaker is plugged in. Easy fix, wired the internal speaker direct to the output transformer.
Now there is a faint hiss coming from the loudspeaker but no stations coming in. Move on to the IF amplifier and I find two transistors TS6 and TS5 have base to emitter short circuits. There's evidence that these transistors are not the originals being AF121s, the factory fitted transistor were AF126s. Replacements will be fitted and the results will be reported later today.
What is of concern, what is causing the transistors to fail?
DFWB.
ID:	208532   Click image for larger version
ID:	208533   Click image for larger version
ID:	208534   Click image for larger version
ID:	208535   Click image for larger version
FERNSEH is offline
Old 16th Jun 2020, 10:43 am   #2
FERNSEH
FERNSEH's Avatar
Default Re: Philips L6X38T "Antoinette".
IF amplifier transistors TS5 and TS6 replaced. Hiss level has increased proving that there is some activity from the front end of the receiver. The AM/FM switch has contact issues. Still no stations coming in.
DFWB.
FERNSEH is offline
Old 16th Jun 2020, 1:27 pm   #3
OldTechFan96
OldTechFan96's Avatar
I have a Philips set from 1968 which looks to have identical switchbanks. They were the cause of the set being dead on all bands. They look to be an interesting attempt at miniaturisation.
The 'stem' that moves up and down can be removed and the metal contact fingers can be retentioned, giving a better contact.
The stems are made from a thin metal shim which is covered in plastic. In my radio, the plastic was cracking in places and needed to be reglued.
OldTechFan96 is online now
Old 16th Jun 2020, 2:03 pm   #4
OldTechFan96
Here are some photographs of the switches and an example of a stem.
ID:	208613   Click image for larger version
ID:	208614   Click image for larger version
Old 16th Jun 2020, 3:27 pm   #5
FERNSEH
FERNSEH's Avatar
Hi OldTechFan96,
Thanks for posting up the pictures of the switches. The first switch to receive attention will be the AM/FM switch. FM stations were heard today so we know the tuner is OK. The three stage IF amplifier is working which means the AM mixer will be OK as well. The separate AM oscillator transistor is OK.
Would be a shame to give up on the set having got so far with the repair.
DFWB.
FERNSEH is offline
