21st Jan 2013, 3:43 am | #21 |
Re: installing windows 95 in early laptop
Linux has to be on a DVD.
The ISO is 1.3GB. http://www.pclinuxos.com/?page_id=180 There is an issue that looks like you need to check the updating system. It is explained on the home page. http://www.pclinuxos.com/ |
21st Jan 2013, 9:15 am | #22 |
Kevin
from distant memory: for a Win95 installs from a CD on old hardware you need to have a boot floppy with Autoexec.bat, Config.sys, Command.com, and a CD driver file to load onto your Hard disk after formatting it. Alternatively Format the Hard Disk with the boot option enabled and then use a generic CD Rom driver install disk to access the CD drive. The Config.sys or Autoexec.bat file(s) carry the links to start the CD Rom driver file so it remains 'alive' after a re-boot, allowing the CD Rom to work properly, although you will have to use a Dos command to actually run the CD. After this, try: "cd:\ {drive letter shown during the CD Driver install}" - think the CD may auto run from then otherwise try "Install" at the Dos prompt? (please correct syntax if incorrect, as I haven't used Dos for over 12 years!) hope this assists Mik |
21st Jan 2013, 10:35 am | #23 |
There are many different Linux distributions available, most of which fit on a CD. The best distro for this purpose is probably Puppy Linux, which is a 170MB ISO. There are many smaller distros than this.
21st Jan 2013, 10:44 am | #24 |
If you are struggling with Win 95 why not try win 98 which you may find easier. I think 98 is a bootable CD. If you do not have a 98 disc then pm me and I will send you one. Also have a read through these posts to see if they help http://www.overclockers.com/forums/s...d.php?t=275949
21st Jan 2013, 1:51 pm | #25 | |
I tried to install Win 95 in a virtual box on that machine but fell flat at the display setting stage since guest additions are only easily installed for Win 2k and upwards. However the relevance to this thread's topic is that, with Puppy running on that machine, then the Win 95 CD placed in a - period option - CD device that fits in place of the R/H battery, floppy drive or whatever other device I wanted to put in there, the system recognised the CD and offered the option to install 95 alongside Puppy so even without using Linux as an alternative, a light distro such as Puppy or Damned Small would allow 95 to be installed on a dual boot basis, alongside the Linux distro of your choosing. You could then adjust the boot options in Linux to set the 95 to the top of the list and reduce the decision time to 1 second, effectively starting 95 from boot. It worked but only really served to remind me of just how far home computing has progressed. May I ask what software it is that would only run under 95? There's usually a way around such an obstacle.
John. |
21st Jan 2013, 3:46 pm | #26 |
Linux does have legacy software drivers.
I used a PCLinuxOS legacy driver to run a circuit CAD package with success. It is called Wine and you download it from the update site. |
21st Jan 2013, 6:12 pm | #27 | |
21st Jan 2013, 7:49 pm | #28 |
I have just checked on my non floppy laptop and Windows 98 does boot straight from the CD.
21st Jan 2013, 10:41 pm | #29 |
A quick search found... http://reboot.pro/topic/3837-bootable-windows-95-cd/ it may help.
25th Jan 2013, 8:26 pm | #30 |
I eventually managed to obtain a W98SE bootable CD rom which worked first time. Relief! I was then able to install the HP driver pack (still available from HP) to reinstate the audio and graphics. I donwloaded it on an XP computer and burned it to a CD-R to get it into the laptop.
The single USB port will recognise my USB-to-com port adapter and I can install the driver for it off its installation disc. But I can't get any 'generic' usb storage devices to work..USB hard drive, usb stick etc. They power up and W98 tells me what they are but can't find any drivers on windows for them. Are there any generic W98 drivers that can be installed? Obviously I have several USB sticks (thumb drives) and I dont relish the idea of trying to track down non-existant W98 drivers for each and every one of them.
Kevin |
25th Jan 2013, 8:44 pm | #31 |
You need to install a generic W98 USB mass storage driver. Software used to be supplied with lots of devices but this is rarely done now because all current OSs have support built in.
If you can't find anything suitable I can probably find something. Try the attached drivers, which came with a USB IDE cable. |
26th Jan 2013, 1:06 am | #32 |
Thanks Paul your driver worked though I had to install it manually rather than running through 'setup'.
Kevin |
26th Jan 2013, 2:09 am | #33 |
I didn't try it as I've not used W98 in donkeys' years. I just zipped the files in the W98 directory. Glad it works anyway.
27th Jan 2013, 3:43 pm | #34 | |
Apologies for the O/T addition but I simply wish to prevent others falling into the same trap:
WINE (capitalised as it's an acronym) is only one component of the "Play on Linux" suite which is included in the synaptic package manager in the distros' applications lists. Open Synaptic, type in "playonlinux" at the top right of the pane then check every box that isn't already shaded green, along with every sub menu when prompted to do so. By downloading WINE in isolation from the repository as you've done, you'll find that screen resolution and other facets of the guest additions won't be recognised and you'll have slowed your machine down needlessly.
John. |
28th Jan 2013, 12:09 am | #35 |
I did use Synaptic and I also had to wait quite a long time for all the extra data to install.
It is also difficult to install manually for most new users of Linux. |
