20th Feb 2013, 4:02 pm | #1 |
Graphite for membrane key-pads!
My (long obsolete) Calcomp 2000 CAD puck is getting old - the keys are not as responsive as they were 25+ years ago. We used to revive the membrane contacts with a graphite pencil but is there special graphite 'paint' or powder available for this or is it once again 'B' pencils?
Barry |
20th Feb 2013, 4:34 pm | #2 |
Re: Graphite for membrane key-pads!
Hi Barry,
Try googling "graphite powder". There seems to be quite a range available in different pack sizes for a variety of uses (eg it's used by locksmiths and as a colouring pigment in casting resin, so you may be able to get some at a local locksmith or craft shop. Otherwise, it's back to pencil lead and glasspaper! All the best Terry
Terry the Morganist |
20th Feb 2013, 4:49 pm | #3 |
e.g. http://www.ebay.co.uk/itm/C-K-Graphi...item20cf5cf2e0
I've also had success gluing-on little discs of aluminium cooking foil, formed by placing the foil over a piece of old Christmas card and using a hole punch like one would use to make the holes in paper so that it can go in a ring binder. N. |
20th Feb 2013, 6:13 pm | #4 |
You can buy the conductuve pieces. look up 'carbon pills' and avoid the flatulence treatments
21st Feb 2013, 1:15 am | #5 |
I believe there's a graphite/glue spray (used for spraying conductive coatings on plastic boxes?) that's good for this. This stuff I believe:
http://www.rapidonline.com/mechanica...coating-30090/
21st Feb 2013, 10:52 am | #6 | |
Regards Symon. |
21st Feb 2013, 1:47 pm | #7 |
Thanks lads... I think a one litre can might be a tad OTT!
22nd Feb 2013, 3:09 pm | #10 |
I have always shied away from using graphite powder on membranes in case it 'falls off and shorts' - does it stick satisfactorily to the rubber and ipso facto, my fears needless?
Barry |
23rd Feb 2013, 10:44 pm | #11 |
I found a repair kit (in the USA) for one of my keypads. It was some sort of paint, much like the heated rear window repair kit used for cars. Worked for a couple of more years.
David |
