Old 18th Feb 2018, 8:32 pm   #1
Tyso_Bl
Tyso_Bl's Avatar
Default Weller TCP stand sponge replacement
For those of us who prefer our jeans to the sponge in the stand, made out of a piece of discarded jeans, works well without wetting, yes I know there is no bit in the iron at the mo!
Adapt, Improvise, Oh Bother.....
Tyso_Bl is offline
Old 18th Feb 2018, 8:42 pm   #2
evingar
evingar's Avatar
Default Re: Weller TCP stand sponge replacement
As long as they are "old style" 100% cotton.
Cotton and elastane (polyurethane) mix might make a bit of a mess of your tip
Chris
evingar is offline
Old 18th Feb 2018, 9:51 pm   #3
Radio1950
I discarded wet sponges years ago.
I now use a 50mm dia kitchen type stainless steel scrubber tied down with thin steel wire.
The cheaper ones dont have added soap, and work well.
My Weller tips now last much much longer, and no more water and rusting tray.
It takes just a few minutes to get used to wiping the tip in the scrubber, and not hearing the traditional sizzle!
I copied the idea from our Hakkos at work.
Radio1950 is offline
Old 18th Feb 2018, 10:00 pm   #4
MrBungle
MrBungle's Avatar
Interesting solution. I bought a whole bag of Weller sponges recently. Cost me just short of £15 for 5!
I just gave up on the brass wool stuff as it keeps splashing hot solder on me.
MrBungle is offline
Old 18th Feb 2018, 10:16 pm   #5
Outrun_uk
Primark sell round cosmetic cellulose makeup cleansing sponges in yellow, pack of 2 for £1. They look, feel and act practically the same as the rather expensive official Metcal ones....!
Outrun_uk is offline
Old 18th Feb 2018, 10:19 pm   #6
alanworland
alanworland's Avatar
I understand that plunging the hot tip into a cold wet sponge can shorten the life of the iron plating and for that reason I have always used a piece of cloth.
Alan
alanworland is offline
Old 18th Feb 2018, 10:21 pm   #7
Oldcodger
Soldering iron sponges are readily available on the net. I did try to use an old kitchen scrubbing pad, but it melted when it wasn't wet enough. I've never tried it on a soldering iron tip, but when I couldn't get my hands on a bit of "moleskin" for a lead wipe, I found the rear of emery cloth an effective substitute.
Oldcodger is offline
Old 18th Feb 2018, 10:40 pm   #8
MrBungle
MrBungle's Avatar
Having used the same tip on a Weller TCP iron for the best part of 15 years, I'm not sure that is the case. It certainly is on the cheapy irons and the Antexes with copper cores but the Weller ones seem to be made of something completely different.
MrBungle is offline
Old 18th Feb 2018, 11:54 pm   #9
turretslug
turretslug's Avatar
I take on board the points about stainless steel scrubbers being a better option for plated tips, but the same Continental discount stores that do these also do real (non-melting!) spongey sponge scrubbing pads bonded to dark green fibre scourer for not a lot- the scourer layer peels away easily and the sponge can be razored to size.
turretslug is offline
Old 25th Feb 2018, 4:51 pm   #10
jonnybear
jonnybear's Avatar
Made up this over a year ago still going strong and no wear on the bit.https://www.vintage-radio.net/forum/...d.php?t=130230
jonnybear is offline
Old 25th Feb 2018, 5:25 pm   #11
Diabolical Artificer
Diabolical Artificer's Avatar
I've gone through two TCP tips in about 3 month's. The plating cracked on the first, the tip fell off the second. This isn't through using said tips as crowbars.
I used a green scourer and water for a while, which was great when new, but fell to bits after a while. i have got one of those metal scourer things, but it's not as good as a quick swipe on the old jeans.
One thing while were on the subject, I've seen a video that recommends wetting your iron tip before putting it back in the holder as well as when first heating it up, to apply solder as it heats up.
Any tips are welcome to prolong the life of my tips, it's a dear do. 15 years! I wish.
Will give the bit of denim a try, I've only two pairs of jeans to my name, can't afford to go through strides as fast as I go through tips.
Andy.
Old 25th Feb 2018, 5:52 pm   #12
evingar
evingar's Avatar
According to the Metcal rep, that's the case for Metcal stuff tips He recommend the sponge be no more than slightly damp.
Chris
evingar is offline
Old 25th Feb 2018, 10:51 pm   #13
greg_simons
greg_simons's Avatar
Thanks for the tip, I drive a metcal system.
greg.
Picture, sound?, DOOR.
greg_simons is online now
Old 26th Feb 2018, 9:01 pm   #14
factory
As we have so many different brands of soldering irons at work, we found it cheaper & easier to buy these larger sponges;
http://cpc.farnell.com/antex/y023150...antex%20sponge
We cut them to size & cut the hole in the middle same as the originals, you can make a couple of sponges from each. CPC seem to be little cheaper than RS (used at work).
factory is offline
