Old 11th Apr 2020, 5:48 pm   #1
Malcolm G6ANZ
Malcolm G6ANZ's Avatar
Default Marconi CR300 drum drive
A plea for sanity. I have to re-thread the drum drive on the CR300 as there wasn't one there when I got given the set so I'm starting from zero.
After many attempts I have got the string around the switch drum, under the chassis, hopefully in the correct cw/ccw winding. The manual then ,glibly, states to tie on the spring and fit the spring into hole on the drum.
How is this possible? I have tried a couple of times to fit the spring with the string tied on to it and always end up with the string coming loose and tying itself in knots around the shaft.
Has anyone succeeded id performing this operation, if so how?
Malcolm
Malcolm G6ANZ is offline
Old 11th Apr 2020, 6:08 pm   #2
ms660
ms660's Avatar
Default Re: Marconi CR300 drum drive
Mine was pig but do able in the end:
https://www.vintage-radio.net/forum/...ad.php?t=77128
Lawrence.
ms660 is offline
