Old 28th Dec 2016, 3:33 pm   #1
MALC SCOTT
MALC SCOTT's Avatar
Default Elpico car radio ID
Hi, i have picked up an old Elpico car radio which i intend to fit to my 1957 Standard 10. I need to know the model number of it as i need a cct diagram to repair it. Here are some pics, Malc.
ID:	135039   Click image for larger version
ID:	135040   Click image for larger version
Malc Scott
MALC SCOTT is offline
Old 28th Dec 2016, 11:24 pm   #2
Herald1360
Herald1360's Avatar
Default Re: Elpico car radio ID
From the look of that, you're probably looking at AF11x problems in that module.
As a radio, it's a bit late for a Standard 10- that would have had a valve or possibly a hybrid set in the late '50s.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is online now
Old 28th Dec 2016, 11:47 pm   #3
Biggles
Should be fairly straightforward to fix. As has been said, that module probably has some AF117's in it. The output stages on this type of radio often consisted of a power transistor (probably the one on the back panel) in class A feeding an output transformer a bit like a typical single ended valve output stage. If the radio had the correct supply fuse fitted this may have saved the output transistor from frying itself if there was a fault, otherwise this may be a good place to start if you have absolutely no output or the whole set takes too much current.
Alan.
Biggles is offline
Old 29th Dec 2016, 9:56 am   #4
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
That (TO-3) Transistor, almost certainly an AD149 or OC26, is the output device, and, as Alan(Biggles) says, drives the speaker via a transformer. Typical current consumption for radios of this type is ca, 600-700mA, or about 800-900mA including the pilot bulb, at 13.8V (i.e. from a nominal 12v supply.
'LIVEWIRE?' is offline
Old 29th Dec 2016, 11:04 am   #5
boxdoctor
Hi Malc,
As far as I remember, the Standard 10 is positive earth. Is the radio also positive earth (or switchable between the two)?
Would be a good idea to check before powering it from the car..... Tony.
boxdoctor is offline
