28th Apr 2014, 9:24 am | #1 |
Removing scratches from Perspex?
The Perspex cover on a record player I'm restoring is scratched, only surface marking nothing severe.
Looking for recommendations on the best technique to remove them or improve them to an acceptable standard.
BVWS member |
28th Apr 2014, 10:37 am | #2 |
Re: Removing scratches from Perspex?
I've had good results using Brasso and a soft cloth on Perspex (acrylic) including on the lid of a Technics SL-1200 which was quite badly scratched. Just make sure the cover isn't some other kind of plastic first: polycarbonate, in particular, reacts very badly to Brasso. Try on a small, hidden area first, as they say.
Chris
28th Apr 2014, 9:31 pm | #3 |
Yes, depends very much on the scratch depth and even seemingly surface scratches can actually be a lot deeper than you imagine.
I've had success using 1200 grit wet&dry paper used dry (car accessory shops) followed by T-cut. The trick with w&d is to keep the sanding motion circular and low speed. You should be able to sand to a smoothness that doesn't show any marks - te persex just goes opaque to some extent. |
29th Apr 2014, 1:55 am | #4 |
An old trick with fine wet & dry paper is to wet it and apply a little soap.
29th Apr 2014, 5:57 am | #5 |
Rather like car paintwork; depends on whether you've got relatively deep scratches or just swirls and haze. For the latter, I too have found that T-Cut is cheap and works well (though I don't use it on modern paints). I've also heard favourable comments about toothpaste.
B |
29th Apr 2014, 2:28 pm | #6 |
An advisory on my last MOT told me that the plastic lenses on my headlights were deteriorating with potential loss of light output. I used the fine wet and dry paper technique going progressively finer and then polished up with T-cut. It was a bit disconcerting at first as under action from the paper the lenses started to look opaque but then the T-Cut brought back the clarity and sparkle.
There is a liquid sold by motor factors specifically to polish up plastic headlight lenses. How different this might be from T-Cut I don't know. Last edited by Junk Box Nick; 29th Apr 2014 at 2:29 pm. Reason: added word |
29th Apr 2014, 2:32 pm | #7 |
As others have mentioned, Brasso applied using a new, clean duster is a good place to start - that's what I've used in the past to 'improve' the Perspex windscreen of a late-1940s racing car.
29th Apr 2014, 5:24 pm | #8 | |
Brasso and a soft cloth as mentioned is a good start, aterwards some silicone polish like Mr Sheen does a super job. |
29th Apr 2014, 9:25 pm | #9 |
I am a member on another thread that uses Novus polish. It comes in different grades and is used for polishing Pinball machine tables to a mirror finish..
33, 45, 78, around and around they go...
29th Apr 2014, 10:22 pm | #10 |
Judging by the colour of T-Cut, I've always believed that it's essentially no more than "Jewelers Rouge", i.e. fine particles of iron oxide in suspension. I believe that by the standards of more modern products, it's actually fairly coarse. As per headlights, that's the appllication where I gather toothpaste has proven good; I think most toothpastes have fine powdered silica in them to give them both consistency and cleaning properties.
29th Apr 2014, 10:54 pm | #11 |
G-QRP #12697 Last edited by radioman; 29th Apr 2014 at 10:55 pm. Reason: more detail |
30th Apr 2014, 12:09 pm | #12 |
Just going to say Andy,Greygate does the stuff used on fighter aircraft cockpit perspex.
Having used it and found to be excellent.
