31st Dec 2015, 2:21 am | #1 |
Inductance
As we all know when an inductive load like a motor or flourescent choke ison an AC supply it feeds a little bit of current back into the supply this can in theory last for up to 5 millisecond under worst conditions but will the fact that the next cycle of the mains is going to opose that actually stop some of the energy going back because as mains volts exceeds choke volts it will stop the reverse current flowing?
31st Dec 2015, 5:00 am | #2 |
Re: Inductance
In steady state (after any switch on transients have settled) an inductor will alternately store energy from the supply and return it twice per cycle. This means that at times in each cycle the current is flowing in the opposite direction to the applied voltage. Is this what you are thinking of?
31st Dec 2015, 9:54 am | #3 |
Re: Inductance
If you used an oscilloscope, it would show you the mains voltage as a sine wave, and if you sampled the current you would see that it was also sinusoidal, but phase shifted by 90 degrees (a quarter of a cycle) The current lags behind the voltage.
31st Dec 2015, 11:50 am | #4 |
Re: Inductance
When 'mains voltage exceeds choke voltage' it starts to reduce the reverse current. Choke current doesn't depend on the voltage, but on the accumulated history of voltage. Just like your car's speed does not depend on acceleration, but on the accumulated history of acceleration (and braking)
31st Dec 2015, 12:26 pm | #5 |
Re: Inductance
And if you had a hand-cranked alternator connected up to an inductive load, you would be able to feel a stiff spot as you stored up energy in the magnetic field and then an "easy" spot as it was released. Whereas with a resistive load, the force opposing you turning it would be constant all the way around.
(Someone's really got to build a demo version of that. With polished brass, ebonite and mahogany, of course ...)
31st Dec 2015, 12:52 pm | #6 |
Re: Inductance
Thanks for the quick reply yes I realise the forward current is shifted out of phase I've seen that on a scope I was just trying to make sure I understood what happened with the choke's return current I think I do now. Julie m yes if we could get someone to build a model like that it would be great! Alas my engineering skills are ropey at best HAPPY NEW YEAR and thanks to you all
31st Dec 2015, 2:18 pm | #7 | |
Re: Inductance
31st Dec 2015, 3:32 pm | #8 | |
Re: Inductance
31st Dec 2015, 5:44 pm | #9 |
Re: Inductance
Radio wrangler that would be good I would go back in time and make sure they didn't close radio Luxembourg on 208
