Old 19th Nov 2021, 11:43 am   #21
The Philpott
The Philpott's Avatar
Default Re: AVO Light Meters
From 55 shillings to 67/6...? - ie hovering around the £3 mark. Expensive, but not expensive to the point of profiteering. I haven't seen one of these before.
Paul Adams, incidentally, is the guy who at the second attempt performed mould-based 'plastic surgery' on (one of the two known) examples of the AVO military OY/Type 107 Testmeter. This was a meter fascia that many of us, me included, would have given up on.
Dave
The Philpott is offline
Old 19th Nov 2021, 12:07 pm   #22
sortedradio
sortedradio's Avatar
I have an old AVO expousure meter. It still responds to light, but I doubt it's calibrated! It measures approx 50 x 50 x 33mm deep.
ID:	246116   Click image for larger version
ID:	246117   Click image for larger version
Martin
BVWS member
GQRP Club
sortedradio is offline
Old 19th Nov 2021, 12:50 pm   #23
Superscope
Hi Martin,
That's a Metrovick meter, made by the Manchester based Metropolitan Vickers Company.
Nice little Meter though.
Ian
Superscope is offline
Old 19th Nov 2021, 1:04 pm   #24
sortedradio
You are right Ian, must go to Specsavers (other opticians are available)!
Martin
BVWS member
GQRP Club
Old 19th Nov 2021, 1:08 pm   #25
Superscope
Every time you dig in and research the Avo Company, it always gets
more complicated than expected.
Just been checking out the Exposure Meter Patents.
Philip Charles Smethurst has one listed Uk Patent, applied for on 15th June 1936
which directly relates to the Meter in the Photo on my previous post.
However, Hugh Sutherland McCadie on the other Hand, has at least Three Uk
Patents relating to Exposure Meters dating from 1934, 1936 & 1947.
So, on second thoughts, the Smethurst Meter probably wasn't Avo's first after all.
Still a very nice and very Rare Light Meter though.
Ian
Old 19th Nov 2021, 5:03 pm   #26
wd40addict
wd40addict's Avatar
Smethurst wrote many articles about his highlight method before the war, it seems to have faded away post war. Possibly improved emulsions made it less critical, or it may have just inspired the incident measurement method which AVO and others certainly made use of.
wd40addict is offline
Old 19th Nov 2021, 6:18 pm   #27
That looks remarkably like photo one in the original post.
Old 19th Nov 2021, 8:35 pm   #28
pmmunro
The one I have has no reference to Smethurst on the front panel but is otherwise very similar to the ones which appear above. The Serial number is 15489-578 and the Patent No. (458546) is also marked on the front. From the Patent and Serial numbers it would seem a reasonable guess that this one is from 1938.
The Science Museum also seems to have one.
https://collection.sciencemuseumgrou...exposure-meter
PMM
pmmunro is offline
Old 20th Nov 2021, 2:07 am   #29
Granitehill
I've got a (quite) modern AVO LM4 meter which I used to sort out some domestic lighting probs. I got it from our favourite auction site for about £30 or so.
It's industrial rather than photographic - scaled 0-500 and 0-2000 LUX. I guess it's a bought-in and badged item, because it's got "Made in France" on the bottom. It's got a threaded socket on the underside, so probably used on a fixed tripod as well as hand held. It's designation as the "LM4" suggests that there were also LM1 - 3 in earlier times.
John G4FDD
G-QRP 431
Granitehill is online now
Old 21st Nov 2021, 9:33 am   #30
wd40addict
wd40addict's Avatar
Here's a couple of period adverts from 1937. The Smethurst version carries a one guinea premium over the standard model!
ID:	246272   Click image for larger version
Old 21st Nov 2021, 10:24 am   #31
Superscope
wd40addict,
Do you know which Publications those Adverts came from ?
Ian
Old 21st Nov 2021, 12:35 pm   #32
wd40addict
wd40addict's Avatar
They're from my 'Amateur Cine World' collection.
Old 28th Nov 2021, 9:46 am   #33
pmmunro
Here is a little more information on the AVO Exposure Meter - a sales leaflet, presumably from the 1930s.
PMM
pmmunro is offline
