2nd Dec 2021, 10:24 am | #1 |
Phillips N4308 part names or sources
Hello all, All cleaned up and new belts fitted and works well. However the clip that holds on the tape counter pulley wheel flew off when removing it never to be seen again! Also the rubber washers on the four corners could do with replacing. Could anyone give me the names of these items please. As you can see it is not a normal C clip (I might try a blob of hot glue) and the rubber washers have a groove in the middle.
Rich |
2nd Dec 2021, 10:48 am | #2 |
Re: Phillips N4308 part names or sources
Welcome aboard! An ordinary circlip would do for the counter pulley and the things in the deckplate are grommets, widely available on auction sites.
2nd Dec 2021, 2:08 pm | #3 |
Many thanks for your reply Ted
2nd Dec 2021, 8:13 pm | #4 |
An E Clip (type of circlip) would also suffice.
David |
