3rd Nov 2021, 8:55 pm | #281 | |
Re: Commodore PET 2001 voltage regulators
As you say, it was a problem to be found and pleased we have. I just hope there are no more gremlins hiding away when this is (hopefully) fixed! Tim. |
3rd Nov 2021, 9:39 pm | #282 |
Well...
Have you had a look at that shift key yet? |
3rd Nov 2021, 9:57 pm | #283 | |
Alan |
3rd Nov 2021, 10:03 pm | #284 |
I've been getting ready for the new IC to arrive, so there's now a socket for UA7. Just to make sure all was okay, I've reinserted the original chip and the voltages reflect what I originally recorded; plus the IEEE test code still reports the pin 7 issue. So at least it's consistent and I'm happy the socket seems to be okay.
So I should now be ready for when the new IC arrives. |
3rd Nov 2021, 10:06 pm | #285 |
While Colin's machine certainly had been in an almost fatally damp environment I haven't had much of a sense that that was the case with Tim's, except for the fact that his UD5 PROM had a couple of pins nearly corroded off.
There was a recent thread somewhere else about plastic vs. ceramic IC packages and how plastic ones were more prone to water absorption, or something along those lines. I can't remember where that was. |
3rd Nov 2021, 10:08 pm | #286 |
I've been meaning to mention this and the shift key is now working. After viewing the video Colin posted I was going to get ready to remove the keyboard. However, I just thought I'd give the key a few, repeated presses and it eventually sprang into life! Again, it seems like I have been quite fortunate with the keyboard, especially after reading about Colin's issues with his (and others I've read/seen). As it stands, all the keys work, and they certainly had a good workout for the inputting of the IEEE code.
Tim. |
3rd Nov 2021, 10:16 pm | #287 | |
A few of the ICs do seem to have darker pins, but the UD5 PROM was the worse; it lost one leg and a couple more were very loose. Talking of PROMs, that's really good news about the Hitachi EPROMs you bought from eBay and were able to program. Tim. |
3rd Nov 2021, 10:16 pm | #288 | |
At least that will allow you to prove, definitely, that UA7 was faulty once you have a replacement. -Put new UA7 in - fault goes away. -Put original UA7 in - fault comes back. Or that's how I see it going, anyway. It's always nice to be able to show that a device you replaced was definitely faulty. |
3rd Nov 2021, 10:22 pm | #289 | ||
It's really useful having the two test POKE/PEEKs, as well as the IEEE test code. I think with those, and being able to switch the ICs, we'll have a definite answer. Tim. |
3rd Nov 2021, 10:43 pm | #290 | |
I can't find the ceramic package post/thread either but ceramic chips generally seem to have a better reputation for longevity than their plastic bretheren. Good news with the shift key Tim. Alan |
3rd Nov 2021, 11:44 pm | #291 |
4th Nov 2021, 12:25 am | #292 | |
I believe they will directly replace UD5 (The BASIC Toolkit), UD6, UD7 and UD9. UD8 is a bit of a special case because it is a 2K device which must only be enabled when the address is E000-E7FF. The peripheral ICs (VIAs, etc) are mapped into the E800-E8FF range. If you were to put a 2532 in there it would be enabled whether A11 (pin 18) was high or low and would clash with the peripheral ICs. On the original UD8 PROM device, pin 18 is 'CS2' which is an active-low enable, so the original chip is only enabled when A11 is low. By pure luck rather than design you can put a 2716 in UD8 position and the way the pins fall, with 2716 CE landing on the socket's A11, it will work, so UD8 would need to be a 2716. Or ... You could also use a 2732 (not 2532) as UD8 - if a 2732 was inserted in UD8 position then pin 21 (its A11 pin) would be held permanently high - therefore the code would need to be programmed into the upper half of the device, but as long as that was done, it should work. |
6th Nov 2021, 8:57 pm | #293 |
Hi. Just thought I'd give a quick update. The ICs from Cricklewood Electornics arrived today, so the replacement UA7 was put in place. The voltages (after running the POKE) on pins 9, 11, 13, 15 were all identical, and the two POKE/PEEK commands both returned the correct values.
I then loaded the IEEE code, and it looks like all is well after running it. I left the code just looping for 1 hour 30 minutes, and each pass went through successfully. So it looks like the replacement chip is all good, and the IEEE seems a lot happier! Just want to say many thanks once again for all the help and support provided. It really has been appreciated. Tim. |
6th Nov 2021, 9:26 pm | #294 |
Alan |
7th Nov 2021, 12:24 am | #295 |
well done another fully restored PET
7th Nov 2021, 10:56 am | #296 | |
Alan |
7th Nov 2021, 1:11 pm | #297 | ||
https://cpc.farnell.com/duratool/d00...P=TREML007-005 I’ve found it to be really good, providing it’s cleaned after each use. I just add a small amount of new solder to the pins when using it, and it really seems to help get the old solder out cleanly. Tim. |
7th Nov 2021, 1:15 pm | #298 |
7th Nov 2021, 2:17 pm | #299 | |
Don't push your luck too far with the PET or it'll throw another wobbly! Seriously though mine's behaved impeccably since its return to full health earlier this year. I'm even considering giving it an SD2PET for Christmas. Alan |
7th Nov 2021, 2:33 pm | #300 | ||
I know what you mean about pushing my luck! I’m just pleased to have it all working now. I’m also looking at the SD2PET as well. It looks a good piece of equipment . I think I’ll also have to start looking at cleaning up the case/keyboard as well; there are a couple of light rust marks, so this could be the next job. Tim. |
