12th Sep 2018, 8:31 pm | #1 |
Garrard RC80/RC80M Differences
What are the differences between the Garrard RC80 and RC80M models? Superficially, they appear to be identical, other than the head shell design and the RC80 head shell not having a finger lift.
I did a quick search of the forum and could find no references to this. Thanks |
13th Sep 2018, 11:19 am | #2 |
Re: Garrard RC80/RC80M Differences
There's no real difference between the two other than the quality of the finish. you'll find such things as chromed parts on the '80' that are just painted on the 'M' etc. You also can't tell by the head shells as different ones were used between the models. Some models had fixed heads and some had detachable heads on the same model suffix. Engineering tolerances can differ between models, such as you may not be able to swap the platter between models as it may sit too low on one and scrape the mechanism below. You'll find, however, that the complete spindle assembly can be interchanged between models to match the platter - etc. etc. Otherwise they're the same. I think the 'M' model was just a cost cutting version of the straight '80', but with possible slight engineering updates.
